Thread gauge
Thread gauge
Home › Forums › Beginners questions › Thread gauge
  • #11495
    Milly S
      @millys
      #648650
      Milly S
        @millys
        Hello all
        I bought some thread gauges at boot sale
        can someone explain why some have
        numbers & letters on ie 13g
        & some just have numbers are the ones with numbers
        for thread pitch
        thanks
        Steve
        #648653
        not done it yet
          @notdoneityet
          Posted by Milly S on 15/06/2023 20:52:32:
          Hello all
          for thread pitch
          thanks
          Steve
          Measure and work out the pitch to see if that is what they indicate?
          From the net:
          “What are the different types of thread gauges?
          Thread gages can be one of any number of types of gages. These in clued plug, ring, 3-wire, micrometer, tri-roll comparator, measuring wire, screw thread insert (STI), and thread gaging roll thread gages.
          What type are yours?”
          #648655
            The German word for ‘thread pitch’ is:
            Gewindesteigung
            Georgineer
              @georgineer
              A bit more detail would help people to help you, but 13g could possibly be "13 gauge" which would be the thread on the end of a particular diameter of wheel spoke. My 1938 tandem used 13g spokes.
              George
              #648659
              Frances IoM
                @francesiom58905
                assuming you have the common arrangement of two sets of blades sandwiched between two plates – then these plates usually have whit or metric or both stamped on them – on those under the whit heading they are marked in tpi turns per inch and under the metric the thread in mm – should be fairly obvious ‘g’ is used on german or european origin for tpi – there are funnies available eg BA threads but 99.9% are combi Whit + metric
                #648661
                Hopper
                  @hopper
                  13G usually means 13 threads per inch.
                  It is the metric way of describing TPI without referring to the verboten inch. As MG says, it stands for the German word for thread pitch. Older imperial thread gauges just have the number, indicating TPI.
                  #648663
                  Steviegtr
                    @steviegtr
                    I am glad someone asked this question as I have some the same & had no idea what it meant.
                    Steve.
                    #648664
                    Nicholas Farr
                      @nicholasfarr14254
                      H Milly S, this 13G? thread may also have answers for you.
                      Regards Nick.
                      #648684
                      Milly S
                        @millys
                        Good morning all
                        i would just like to say thanks for all your advice
                        i now know what the G is for
                        & I hope it’s helped others
                        cheers
                        steve
