Test Boiler
Test Boiler
Home › Forums › General Questions › Test Boiler
  • #22271
    Bryan Findler
      @bryanfindler51446
      Obtain Boiler Kit
      #101240
      Bryan Findler
        @bryanfindler51446
        Can someone tell me if there is any other supplier for a kit to make a injector test boiler to run at a pressure of 80 psi. I know G.L.R do one but there's are only tested to 40 psi .
        #101467
        nigel jones 5
          @nigeljones5
          Is this some special type of boiler? Just build a simple boiler, surely?
          #101469
          AndyP
            @andyp13730
            Bryan
            D.A.G. Brown's excellent book "Miniature Injectors Inside and Out" has a design for a suitable boiler which may well be based on the GLR offering – uses 10" of 4 1/4" tube.
            Andy
            #101507
            Bryan Findler
              @bryanfindler51446
              Hi Andy I have got that book but he does not give all that much detail about . Bryan
              #101552
              AndyP
                @andyp13730
                Bryan,
                Sorry I hadn't read it through, it is a bit thin on detail but I think I could build it from that, the inner firebox looks thin and he does say it moved so he added stays, I think I would just use thicker tube. Foundation ring is going to be 3/8 square copper and the unspecified firehole ring is just thick tube say 10swg and maybe 1 1/4" If you are going to gas fire it does it need a firedoor anyway?
                It does say it is a modified GLR test boiler so you could talk to GLR first – may be easiest to start with that and do DAG Brown's modifications as you build it.
                Andy
