Temporary loctite for drilling
Home › Forums › Workshop Techniques › Temporary loctite for drilling
  • #15745
    Nick_G
      @nick_g
      #172376
      Nick_G
        @nick_g
        I have read (somewhere.???) that you can bond 2 or more metal parts together with loctite. Drill the holes and once done you can separate them with the use of heat.
        I ask this to assist the drilling of the valve chest and cover for the Stuart engine I am building.
        Is this fact or myth. Has anyone done this and is it a particular loctite grade that is used.?
        Cheers, Nick
        #172378
          Nick,
          Be aware that "Loctite" is a brand-name … it used to be generally presumed to mean the anaerobics [of which there are many grades], but is now also used for their cyanoacrylate "SuperGlue" products.
          The anaerobics are excellent for cylindrical fits, but their adhesive effect is actually quite poor, so they are not very suitable for bonding flat surfaces.
          You can however, bond your parts together with cyanoacrylate, and then disbond later by soaking the assembly in water.
          Fatgadgi
            @fatgadgi
            Hi Nick
            Yes, it works – I often use super glue to hold things together for drilling, light milling etc.
            The bond is easily broken afterwards by heat (250 degs) or sometimes a sharp hammer blow.
            You will have to clean the adhesive off afterwards though.
            Cheers Will
            #172384
              Posted by Will Bells on 13/12/2014 00:25:35:
              You're right, of course, Will
              … Best choice of removal technique really depends upon the nature of the workpieces.
              [Nick]: I should also have mentioned that this technique is a variant of the Watchmaker's "Wax Chuck", where Shellac is traditionally used as the adhesive.
              Edit: See here for a good note about using Shellac on larger work.
              Edited By Michael Gilligan on 13/12/2014 07:47:13
              #172387
              Nick_G
                @nick_g
                Cheers guy's.
                Nick
                #172469
                stan pearson 1
                  @stanpearson1
                  Hi Nick
                  Industrial super glue is what I always use or soft solder paint, Loctite does not work as said on flat surfaces
                  Stan
                Home › Forums › Workshop Techniques › Topics
