Telescoping tubes needed
Home › Forums › General Questions › Telescoping tubes needed
Viewing 14 posts - 26 through 39 (of 39 total)
  • #142425
    OuBallie
      @ouballie
      Martin,
      No strop shown in the manual, which I will post if I can find the effing thing.
      I, of course, put said manual in a safe place, so nuff sed!
      I did do a photocopy so those are on one of my hard disks, but which one?
      Geoff – Retirement is supposed to be relaxing.
      #142429
      V8Eng
        @v8eng
        Retirement relaxing! Not stopped laughing since reading that.
        I Retired early with the intention of getting on with hobbies, some relaxing time, and a general de-stress.
        Since then I never seem to have a spare moment, There is much less time for any hobbies and one sort of stress has been replaced by others.
        How did I ever manage to fit in a full time job as well?
        Having said all that there is no way I would want to return to the previous scheme of things.
        Edited By V8Eng on 01/02/2014 16:07:55
        #142431
          Geoff,
          It's probably no more helpful than my previous post
          … but you might like this.
          Edit: and these references.
          Edited By Michael Gilligan on 01/02/2014 16:19:14
          #142436
          Martin W
            @martinw
            Geoff
            Like you I have several of those safe places and only find them when I have purchased a replacement for whatever was put away 'Safe', and always no replacement then no find. I think that when you retire there is some unknown force that comes into play which reduces the length of the useful day, perhaps its something like 'Dark Time' and related to Dark Energy/Matter.
            Martin
            #142450
            colin hawes
              @colinhawes85982
              Does it help keep the tyre wall in its well and possibly lift one wall to ease tyre lever entry? Colin
              #142520
              Gordon W
                @gordonw
                On tyre changing- Assuming no access to a garage tyre changer. Easiest way to get tyres off the rim is to use an old spade, place on rim/ tyre joint and stand on spade,cracks the seal easily. Putting on tubeless tyres, a rope round the centre and a stick usually works ( Spanish Windless ?)
                #142624
                OuBallie
                  @ouballie
                  Good replies.
                  V8Eng,
                  How I ever managed to hold down a full time job and prepare my racing car defies belief now.
                  MichaelG,
                  Thanks for the link.
                  Colin,
                  You are closer than you realise, just a*se about face.
                  GordonW,
                  Well worth keeping in mind, provided I manage to remember your method that is.
                  I will assemble the apparatus and take another photo.
                  Geoff – The universe seems to go into reverse on retirement – less time, less energy, eyesight ditto, stamina (what's that)
                  Edited By OuBallie on 03/02/2014 10:59:47
                  #142649
                  OuBallie
                    @ouballie
                    Another photo in this tyre levers saga, this one showing the bits assembled ready to do battle.
                    Now this should help, but if not then the last one will be with it attached to the wheel/tyre ready for action.
                    Barkers Tyre Levers
                    With any luck the instructions will be as well, provided noggin plays fair?
                    Geoff – Drawer organising saga now at the Moddeling Rock stage (I knew it as Mod Rock)
                    #142652
                    Martin W
                      @martinw
                      HI
                      How about an aid to removing the tyre, once first part of the tyre has been lifted over the rim this is used to walk the tyre off the rim altogether. The knurled section gripping the tyre while the bracket section lifts the bead over the rim; or conversely it puts the tyre on to the wheel by walking it over the rim but I favour the first scenario. Either way it means less messing about by the roadside.
                      Or perhaps its an archaic tool for removing certain appendages from a bull to convert it to a bullock crying 2.
                      Cheers
                      Martin
                      PS
                      Gordon  Your Spanish Windlass is exactly the same in principle to the tool I mentioned earlier with a strop and lever but a lot easier to fabricate when one is needed urgently!
                      Edited By Martin W on 03/02/2014 14:25:45
                      #142679
                        Geoff,
                        Just discovered that our hero went Bankrupt
                        … I wonder if the design is any good ?
                        Robert Dodds
                          @robertdodds43397
                          Geoff,
                          I've not seen the Barker tool before but have used this bead breaker to good effect when punctures were a regular occurrence.pict0121.jpg
                          Edited By Robert Dodds on 03/02/2014 22:42:47
                          #143039
                          OuBallie
                            @ouballie
                            MichaelG,
                            Him going belly up in 1905 explains why his implement hadn't become popular.
                            Cars at that time where expensive, so only bought by the well heeled, who would not I think have sullied themselves in changing a wheel let alone a tyre.
                            He was 20 years too early with his invention, priced at 26/- per set.
                            "The Austin Seven the motor for the million" could have saved him.
                            Geoff – Ordered more ModRock to continue the drawer saga.
                            #143545
                            OuBallie
                              @ouballie
                              The things I find.
                              The instructions for using Barker's Tyre Levers now in my Album.
                              Geoff – Garden only under 1" of water
                              #143550
                                Well-found, Geoff
                                Shame it doesn't quote the Patent Number … the ones I found earlier only describe the basic levers.
