stephensons valve gear etc.,
Home › Forums › Help and Assistance! (Offered or Wanted) › stephensons valve gear etc.,
  • #447143
    David Bothwell 1
      @davidbothwell1
      While recently re assembling a part built chassis (Molly) I could not get the mechanism to turn over. I removed the two bottom eccentrics and the wheels turned and eccentric also worked, but connecting the other two back brings the problem back. Could this be caused by the (slightly wrong )setting of the eccentrics on the driving axle?Leads to a further question, Drawings refer to left hand side , Is the left hand side looking from the back of the loco? Many thanks to anyone offering suggestions or solutions!
      #33513
      David Bothwell 1
        @davidbothwell1
        eccentric problem
        #447147
          Is one valve too far out of adjustment and fouling inside the valve chest?
          David Bothwell 1
            @davidbothwell1
            Hello Neil, No the movement in the valve chest is free, but also opening too far in forward movement, but I thought I could re-adjust this when I solved the eccentric issue! Thank for the response
            #447155
            Baz
              @baz89810
              Correct about left, drivers left standing on footplate facing forward, cannot help with valve setting, sorry.
              #447159
              David Bothwell 1
                @davidbothwell1
                Thanks for that Baz, a big help, I,ll get to the bottom of the valve setting somehow/some way!!
