Posted by Manofkent on 11/04/2021 08:08:45:
This happens a lot on my lathe (an ml10 coincidentally).
The chuck has to be pretty well exactly aligned to screw on.
That used to happen a lot on my Speed 10 (ML10 variant) too, but only with the 3-jaw chuck.
It was the register, not the thread, that was the problem – and it was necessary to present the chuck very concentrically to avoid it sticking and failing to engage. I just accepted this because it meant the concentricity of the chuck grip was preserved as well as it practically could be across chuck swaps.
The 4-jaw went on much more easily. I never measured it, but assumed there was a few thou more clearance in the register counterbore on the backplate, justifiable because you'd have to set up any workpiece manually anyway.
In the OP's situation, it may make sense to ease the counterbore a little.
Edited By Mick B1 on 11/04/2021 09:22:46
