Sound and hooters
Sound and hooters
Home › Forums › Locomotives › Sound and hooters
  • #154843
    Bob Brown 1
      @bobbrown1
      Anyone have any ideas on a good sound card/driver what ever you want to call it for a 5" gauge class 08 Diesel shunter, price is not the be or end all but… I would like it to be able to change as the Loco speeds up with an idle when stopped. Input voltage ideally needs to be up to 14V but can I use a voltage regulator if not. The ones I have found seem to be more for the much smaller gauges OO/HO and not sure they are likely to have a good sound outdoors.
      A two tone hooter would be nice as well
      Bob
      #1290
      Bob Brown 1
        @bobbrown1
        #154855
        MichaelR
          @michaelr
          You may find something on this site Here they list sound modules for 5" and 7 1/4" gauge models.
          #154856
            Hi Bob,
            There are lots of cheap single-chip power amplifiers that you could use to beef up the output. This one looks quite good: **LINK**
            Plenty of other options out there though, including stealing the output stage from an old car stereo or using powered speaker..
            Keith Long
              @keithlong89920
              Bob
              Also worth doing a search for "model boat sound units" as well. There are some that are programable for specific engine effects as well as standard offerings. They usually have ship siren/horn effects included as wello which may meet your needs and usually have an input from the speed control to match apparent engine speed to craft – or in your case loco speed. Typically run from 12 voltish supplies.
              Keith
              #154861
              Bob Brown 1
                @bobbrown1
                The problem is probably not volume as amplifier is easy, it is really trying to connect it to the motors or drive wheels optical sensor or similar as a lot of the smaller sound units are for R/C or get there signal from the track.
                Did think a double pot one for the speed controller and the other driving the sound unit.
                Just need to find a decent sound unit with out spending a fortune on it with good sound quality.
                #154865
                Oompa Lumpa
                  @oompalumpa34302
                  The Hooters you are on about, they're not the same ones I am thinking of are they……… <sigh>
                  graham.
                  #154866
                  Bob Brown 1
                    @bobbrown1
                    I just knew someone would comment
                    #154871
                    Oompa Lumpa
                      @oompalumpa34302
                      Posted by Bob Brown 1 on 09/06/2014 17:10:29:
                      Had to be done Bob, had to be done!
                      graham.
                      #157220
                      Bob Brown 1
                        @bobbrown1
                        Went for this one **LINK** in the end with a couple of regulators to give 12v and 5v from the 24v motor supply. I could have done it with a 12v feed off one of the batteries and one regulato but preferred to have the two batteries drain at the same rate.
                        Just need to set it all up in the loco and run a double pot one for the speed controller and one so the engine sound speeds up as the locomotive speeds up.
                        #206735
                        Simeon Jackson
                          @simeonjackson72962
                          Doing something similar but in 2 1/2" gauge, would any of the sound modules/chips linked here be suitable?
                        Home › Forums › Locomotives › Topics
