SOBA rotary table
SOBA rotary table
Home › Forums › Workshop Tools and Tooling › SOBA rotary table
Viewing 25 posts - 1 through 25 (of 25 total)
  • #105221
    Bob Perkins
      @bobperkins67044
      Hi all
      Does anybody have a copy of a user manual/instructions for a 100mm SOBA rotary table they can share?
      thanks
      Bob
      #16945
      Bob Perkins
        @bobperkins67044
        #105224
        Les Jones 1
          @lesjones1
          Hi Bob,
          I don't have a manual on the Soba rotary table but I have this document on using a rotary table which you may find useful. I do not remember the website where I found it. It is in a "Dropbox" folder which I will remove after a few days. If anyone wants it after this time PM me with an email adress and I will send it as an attachment.
          Les
          #105225
          chris j
            @chrisj
            Worth a try
            #105226
            dcosta
              @dcosta
              Hello Bob!
              I have the ”SOBA operation and service manual” for my 6” SOBA rotary table.
              I think it is dedicated to other sizes of SOBA rotary tables.
              If you are interested please let me know and I'll send it to some electronic address.
              If you intend to use the address made available by Chris, please take care to know, first, if the executable file necessary to make the download of the document you want doesn't let some kind of spy or something in your computer.
              Best regards
              Dias Costa
              Edited By dcosta on 01/12/2012 20:34:36
              #105227
              Bob Perkins
                @bobperkins67044
                Thanks Les I have this and there is some useful and interesting info in this.
                Thanks Chris I tried this earlier today and couldn't get the download to work. Perhaps it's an iPad thing, I'll try on the pc later.
                Thanks Dias. An email to [email protected] would be great.
                Thanks all
                Bob
                #105235
                  Posted by Les Jones 1 on 01/12/2012 19:56:29:
                  Hi Bob,
                  Les
                  A very useful document, thank you Les
                  GaryM
                    @garym
                    Hi Bob,
                    Les
                    The document Les linked to is on LittleMachineShops web site here:-
                    HTH
                    Gary
                    #105283
                    Sub Mandrel
                      @submandrel
                      The document Les found is really excellent, but note that it is for a table with a 72:1 (5 degrees per turn) worm. This is unusual as most are 60:1 (6 degrees) or 40:1 (9 degrees) – be aware you will probably need to allow for this.
                      I am inspired to make a larger index wheel for my table with rather more divisions (although 180 to get the same 2 second divisions seems a bit of a challenge!)
                        Note:
                        It's worth going back up to a higher level on their website
                        … Lots of useful info. !!
                        Brian in OZ
                          @brianinoz24148
                          Hello "Bob Perkins",
                          The file is there but as Dcosta pointed out be very carefull as the site will try and download some other software to your PC. When it leaves you at the "download" screen simply use your browser to back-up (go backwards) one screen and you will find one of those little boxes to fill in a code, do this and "submit" then a couple of lines above you will seee PDF you are after, simply "right click" it and save, is a good file.
                          Also thanks to Michael, the PDF you made available is really good
                          Brian in OZ
                          #105306
                          Bob Perkins
                            @bobperkins67044
                            Hi Brian
                            I caught on to that when I looked at the site earlier. It tries to download some type of media playerreader.
                            Thanks
                            Bob
                            #105308
                            Brian in OZ
                              @brianinoz24148
                              Hi Bob,
                              Yes it is one of those sneaky sites, in fact I just checked out the file I downloaded and found it to be corrupted so can't open it. Deleted it and hope I did not get any other "junk" with it, might go back later and figure out what happened, in the meantime I'll do a Google and see if the manual is available elsewhere.
                              #105310
                              dcosta
                                @dcosta
                                Hello Bob Perkins!
                                Have you received the file I sent to you yesterday?
                                If so was it of some help?
                                Best regards
                                Dias Costa
                                Edited By dcosta on 02/12/2012 22:47:40
                                #105312
                                Anonymous
                                  Posted by Stub Mandrel on 02/12/2012 18:13:30:
                                  Oeeeer, I think my rotary table is 90:1, ie, 4° per turn of the handle – Andrew
                                  #105319
                                    Posted by Andrew Johnston on 02/12/2012 23:05:02:
                                    40:1, 60:1, 72:1, 90:1 are all fairly common, and are all "good" ratios for the job, because they have some useful factors. [Although, of course, 40 lacks 3; which must therefore be accommodated elsewhere in the system.]
                                    They are all also factors of 360; which simplifies dividing into "degrees".
                                    P.S. If adding a Stepper Motor to a 40:1 table, it's worth considering a 48-step motor instead of the now common 200-step … so as to introduce the factor 3.
                                    #105320
                                    Bob Perkins
                                      @bobperkins67044
                                      Hi Dias
                                      No email yet. Please try again. I'll send back a thank you message to confirm when it arrives.
                                      Thanks
                                      Bob..
                                      #105321
                                        Posted by Brian in OZ on 02/12/2012 22:06:13:
                                        Hi Bob,
                                        Bob / Brian
                                        I didn't like the look of that site either.
                                        Here is a direct link to six more pages on the LittleMachineShop site.
                                        Bob Perkins
                                          @bobperkins67044
                                          Thanks all
                                          I now have loads of info to look at, including a guide for the SOBA table.
                                          Bob
                                          #105685
                                          John Hinkley
                                            @johnhinkley26699
                                            Now that it looks like you have the answer – can I hi-jack your thread? Some while ago,I bought a 4" rotary table from a UK supplier, but never got around to using it! Now that it's out of guarantee, I've dug it out and tried it. It seems to have been manufactured using a revolutionary elliptical worm gear, in that it has a couple of tight spots when turning a full circle. I'll try to sort it when I have more time. However, my question to you, Bob, is, assuming you've got one, how good is the Soba one? I've arrived in the UK today and was intending to go to Chronos in Dunstable, on Monday, to pick up one with tailstock and dividing plates. Don't want to spend all that money and have a wasted journey if they are of dubious quality!
                                            Bob Perkins
                                              @bobperkins67044
                                              Hi John
                                              I'm really pleased with mine. The quality for the price is good value. I haven't used the index plates or the tail stock yet as I've only had it a few weeks. I've only used it a couple of times to mill 4 slots at 90 degrees to each other. The movement is smooth with no tight spots. I think Cronus supply theirs with a user manual, if not I have a PDF thaks to Dias.
                                              Happy shopping
                                              regards
                                              Bob..
                                              #105707
                                              John Hinkley
                                                @johnhinkley26699
                                                Hi, Bob,
                                                That's marvellous! Looks like a trip up the A5 is on, then. Better break out the credit card!
                                                Bob Perkins
                                                  @bobperkins67044
                                                  Mine came from Axminster
                                                  #105888
                                                  John Hinkley
                                                    @johnhinkley26699
                                                    Bob,
                                                    I'm back from my trip to Dunstable, somewhat lighter in the wallet, but with a 4" soba rotary table, tailstock and dividing plates. I decided that the 6" one was too large for my mill, so I didn't get the rotary table document that comes with that. I'd be grateful if you could pm me a copy ofthe on Dias sent you, if that's OK with him. Thanks.
                                                    Bob Perkins
                                                      @bobperkins67044
                                                      No problem. Send me a private message with your email details.
                                                      regards
                                                      Bob
