Small honing tools
Small honing tools
Home › Forums › Workshop Tools and Tooling › Small honing tools
  • #98659
    Chris Baetens
      @chrisbaetens16442
      Hi guys,
      Where do I get small honing tools. I was thinking of 3/4", and even smaller. I need these to finish stirling engine cilinders. Or maybe there's someone out there using homemade honing tools, and is willing to share his idea..?
      Thanks in advance
      Chris
      #16889
      Chris Baetens
        @chrisbaetens16442
        #98796
        Versaboss
          @versaboss
          For such an application lapping is much easier than (real) honing. Small honing tools are available, but at a price driving water into your eyes!!! Google pemamo.
          A lapping tool can even made from hard wood, and Chinese diamond pastes are cheap.
          Greetings, Hansrudolf
          #98804
          Jens Eirik Skogstad 1
            @jenseirikskogstad1
            For precision lapping such as in model engine or similar, use rod or ring (in case lapping at rod to example) made of copper, brass or cast iron + lapping paste.
            #99551
            David Littlewood
              @davidlittlewood51847
              Chris,
              Go to **LINK** and download the Bruce Engineering catalogue. On about page 70 (the pages are not numbered) you will see a 1/2" to 1 1/4" cylinder hone for about £15. Have one, works fine.
              David
              Edited By David Littlewood on 27/09/2012 23:10:59
              #99561
              Mike Wainwright
                @mikewainwright87512
                Chris
                They are on ebay as well for about £12.00 -£15.00
                #99570
                Phil P
                  @philp
                  Those three legged hones that Bruce and others sell are not true hones, they are what used to be called a "Glaze Buster".
                  A true hone will bring a tapered or out of round hole back true again, the spring loaded type will not as they just follow the existing bore.
                  I am not criticising the spring loaded type because they do have their uses, just pointing out that they are not a cheap alternative to a proper Delapena type hone.
                  I agree with the other comments above, just make a split lap and do it that way. Very easy and very cheap.
                  Phil
                  #99576
                  JohnF
                    @johnf59703
                    Also consider a lead lap, easy to make by casting lead into a mould with a BMS rod to hold it–make a fair bit oversize then turn to size and "load" with lapping paste — cuts like a dream and will produce a round parallel hole. You can also add a tapered pin to expand the lap as required.
                    #99581
                    Ian S C
                      @iansc
                              I find a wooden lap is adiquate for my Stirling Engines, I put a cut down the center of it, an either use a little wooden wedge, or a wood screwin the end to expand the lap. When you finish the course grit, change to another bit of wood for the finer stuff, I sometimes go from brass polish to toothpaste to finish, just to get a mirror like surface.
                              I must try the lead lap, got about 200Kg of lead, so that will go a long way.    IanS C
                      Edited By Ian S C on 28/09/2012 11:59:48
                      #99592
                      wheeltapper
                        @wheeltapper
                        You been up on the church roof again Ian?
                        Roycheeky
