Hi Bob
If you have a joint that is suspect, then at some point you did something that hindered the capillary flow of the silver solder.
Did you use a flux that suited the parent materials?
Did the whole of the joint achieve brazing temperature? Did the alloy get it's heat from the joint not the torch?
Did you create a heat pattern to promote the required alloy flow?
For more information see the videos http://www.cupalloys.co.uk
Keith
Edited By CuP Alloys 1 on 05/12/2019 09:23:31
Edited By CuP Alloys 1 on 05/12/2019 09:24:44
