Signing one’s work
Signing one’s work
Home › Forums › General Questions › Signing one’s work
Viewing 21 posts - 1 through 21 (of 21 total)
  • #193206
    clivel
      @clivel
      When I have a few minutes spare I sometimes like to browse the Station Road Steam website, it contains an excellent archive of photographs of a huge variety of models, some of which have been built to a very high standard.
      While browsing today, it occurred to me that many of these model will live on while the builders often disappear into anonymity.
      Given the enormous amount of time, skill and effort required to produce these models, I find that quite sad.
      Many craftsmen and artists in other fields sign their work so why not the model engineer, perhaps a signature in the form of an unobtrusive plaque or engraved name and date inside the frames for example.
      Or maybe many do, and I have just not noticed it. What do other think?
      #23930
      clivel
        @clivel
        #193211
        Nick_G
          @nick_g
          I have signed my James Coombes 'Leonardo da Vinci' and dated it 1496. surprise
          My plan / hope is to convince a gullible wealthy American that the steam engine was invented and this example constructed hundreds of years prior to when thought by none other than Leonardo.
          I know I have no morals. ………….. But hey-ho.! angel
          Nick wink
          #193212
          Clive Hartland
            @clivehartland94829
            A gun making friend of mine would engrave, 'Fecit' + (Name) around the muzzle of his guns. He had a short name. When I used to make metal replicas of things I always engraved my name on a part of it.
            I endorse Clive1's idea.
            Edited By Clive Hartland on 13/06/2015 07:22:58
            Edited By Clive Hartland on 13/06/2015 07:23:20
            #193225
            Anonymous
              Posted by clivel on 13/06/2015 00:43:49:
              Just what I am planning to do on my traction engines, so at least a future owner might wonder about the builder. Although after yesterday's silver soldering foul up I won't be finishing them any time soon. sad
              #193227
              GarryC
                @garryc
                I have a little engraved plaque on my Victoria but also I downloaded the build sequence from here to DVD so that will get handed down and stay with the engine as well, hopefully it will be found interesting in the future.. One of (but not the main) reasons I'm here – and why I put up as much of the build as I can..
                Garry
                Edited By Gary on 13/06/2015 08:55:34
                #193241
                OuBallie
                  @ouballie
                  Do tell Andrew.
                  Your misfortune may prevent others from doing the same.
                  Geoff – MEW spot welder on the list.
                  #193244
                  CotswoldsPhil
                    @cotswoldsphil
                    As my Minnie is semi-scale, I have had made a makers cylinder plate and smoke-box door name-plates with all the details. I just need to get them cut out and fitted, but as with most ME's I've been side-tracked on other projects.
                    Phil H
                    #193247
                      I'd stick with a maker's plate. The claimed life expectancy of data on DVD is around five years…
                      GarryC
                        @garryc
                        Hi Neil
                        I like your makers plate  (and the engine!), very nice.
                        Yes data would be best be moved from DVD to whatever the latest media might be from time to time, but very easy to do – eventually as technology changes and improves possibly less of a problem as time goes on..
                        You've set me thinking, I think I prefer the makers plate idea to an engraved plaque – if I manage to get through my No. 1 I might look to do that..
                        Cheers.
                        Garry
                        Edited By Gary on 13/06/2015 12:05:56
                        #193261
                        davidsuffolk
                          @davidsuffolk
                          I recently built a full size (but small) vertical engine and the original had a nicely engraved brass cover to the cylinder which I wanted to re-create as best I could.
                          However I didn't want to pretend my machine was actually built by its original maker so, as a compromise, I copied the engraving and in smaller lettering my own name and the date of build.
                          Who knows, in many years, my own machine might become an antique in its own right.dscn2517a.jpg
                          #193359
                          Ian S C
                            @iansc
                            I usually mark my models with name and date in some place out of sight with the Dremel, I feel I should have done something similar when I rebuilt the Stuart Turner S9, it might have been a bit extra to aid it's recovery when it was nicked.
                            Ian S C
                            #193719
                            richardandtracy
                              @richardandtracy
                              If anyone does work they are proud of, then they should put their name on it.
                              Richard
                              #193726
                              Martin Kyte
                                @martinkyte99762
                                I totally agree with the above comments and I would add little story of my own. My clockmaking friend made a bracket clock for his son. Not such an unusual thing as it was amongst a long line of other timepieces. However this particular clock case was of Mulberry wood which came from a very old tree which once stood on the grounds of a large house in the village where he lived, the house having quite a history itself. After a conversation he decided that some record of the clock should be preserved along with it so wrote a short piece describing the origins of the case along with his name and the date when the clock was made. This went into a compartment in the clock so to preserve it's story. If you watch Antiques roadshow and the like, the things that are enthused over more than any other are the objects that tell a story, so why not let your model say that 'so and so made me' and a few details. Make the thing come alive.
                                Martin
                                #193999
                                Dave Halford
                                  @davehalford22513
                                  I punch my intials and the year on all the major parts that I make. One day someone will spot my Minnie took thirty years to finish embarrassed
                                  #196164
                                  Thomas Gude
                                    @thomasgude37285
                                    No fame and glory for me thanks! wink
                                    (more to the point anonymity provides inculpability)
                                    #196166
                                    Alan Hopwood
                                      @alanhopwood63369
                                      As I mainly make tools, a name plate might not be suitable, but I do have a stamp of my Masonic Mark which I dab on the tool somewhere.
                                      I can't claim to have made the punch, but one of my old drinking pals was an engraver (Holland & Holland is one of his customers) and he very kindly carved out a piece of silver steel for me which I then hardened and tempered.
                                      Alan
                                      #196177
                                      Maurice Cox 1
                                        @mauricecox1
                                        I think perhaps, that not enough information on a model is worse than none at all. I have restored an old Stuart number one that predates the adoption of B.A. threads by the firm (1918), so is probably approaching one hundred years old. It carries a plate; "T H CLARK MAKER". That is all. Not even the area where he lived. Such a pity. Mr Clark was obviously proud of his work, and thus he marked it; but now its history is lost. Even if it is hidden, I think that marking your work is a very good idea.
                                        Maurice
                                        #196187
                                        Breva
                                          @breva
                                          Clive……."A gun making friend of mine would engrave, 'Fecit' + (Name) around the muzzle of his guns"
                                          That seems a very appropriate signiture for some of my disasters! I might leave my name off them though.
                                          devil
                                          Jon
                                            @jon
                                            What I tend do is leave no room for any name, luckily for me my work is renowned worldwide and distinctive, but theres always a few that don't know.
                                            Larger items where there could be room I was looking at these from US. **LINK**
                                            Several emails, no answer and assumed he didn't want the business.
                                            #196196
                                            Boiler Bri
                                              @boilerbri
                                              If I ever finish something I will probably mark it some how! Strange at work we turn out 20 to 30 machines a year all with CE plates with date, company name etc on😓 I think my priorities may be wrong😇
                                              Bri
