Should and what with should Sherline threads be lubricated?
Home › Forums › Beginners questions › Should and what with should Sherline threads be lubricated?
  • #493668
    Chris TickTock
      @christicktock
      Hi Guys,
      I have looked at old posts but I cannot readily find the exact question as this question is not about lubricating the inner workings of the chuck.
      My question is the lubrication if any on adapter threads holding a Sherline chuck to the rotary table and the internal threads on the chuck itself.
      Reason they tend to tighten under centrifugal force making removal sometimes difficult.. Is putting lubrication on therefore stupid or sensible and will it make removal easier?
      Chris
      #10418
      Chris TickTock
        @christicktock
        #493672
        Hopper
          @hopper
          Anti-seize grease works wonderfully. And no it doesn't attract any more swarf than oil.
          #493673
          roy entwistle
            @royentwistle24699
            Tighten under centrifugal force.         Surely not
            Edited By roy entwistle on 01/09/2020 11:12:06
            #493719
            Chris TickTock
              @christicktock
              Posted by roy entwistle on 01/09/2020 11:11:39:
              A brownie point for spotting that Roy. Though centrifugal force can creep in to things clamped by a chuck's jaws.
              What I meant is the chuck's thread is orientated not to undo obviously as the chuck spins…else flying chucks everywhere. So the chuck must tighten as it spins on its shaft. What the name for that force is maybe someone can put me right?
              Chris
              #493726
              old mart
                @oldmart
                Torque?
                #493727
                Keith Long
                  @keithlong89920
                  Posted by Chris TickTock on 01/09/2020 14:44:40:What the name for that force is maybe someone can put me right?
                  Chris
                  Inertia
                  #493735
                    I put a little grease on threads like that. Partly for lubrication, but also because it prevents corrosion. I have a theory that Myford Chucks stick because the two thread surfaces glue together due to each growing a slight fur of corrosion.
                    Hopper's suggestion of anti-seize grease is good because some old greases and oils gum up over time. Avoid 3 in 1 oil as a long term lubricant!
                    Chris TickTock
                      @christicktock
                      Posted by SillyOldDuffer on 01/09/2020 16:26:18:
                      Copper anti seize grease OK?
                      Chris
                      #493757
                      John Haine
                        @johnhaine32865
                        Angel's tears.
                        #493775
                        Chris TickTock
                          @christicktock
                          Posted by John Haine on 01/09/2020 19:09:38:
                          Angel's tears.
                          John what have plants got to do with the question? Or are you in a mischevious mood?
                          Chris
                          #493778
                            Copper Grease is fine.
                            Angel Tears Oil? There's exotic! We could be having our legs pulled. Mind you, try anything once…
                            smiley
                            Edited By SillyOldDuffer on 01/09/2020 21:33:07
                            #493780
                            Meunier
                              @meunier
                              Angel Tears Oil?
                              Only from certified ex-pin-head-dancers, please
                              DaveD
