SEASONING OF CAST IRON
Home › Forums › General Questions › SEASONING OF CAST IRON
  • This topic has 33 replies, 27 voices, and was last updated 3 May 2020 at 22:57 by Roger Whiteley.
Viewing 25 posts - 1 through 25 (of 34 total)
  • #467322
    CHARLES lipscombe
      @charleslipscombe16059
      In a recent thread concerning painting cast iron, Andrew Johnston mentioned the seasoning of cast iron. Rather than hijack that thread I have started this one to try and find out a bit more about this subject.
      Certainly it used to be fervently believed that seasoning castings made from cast iron was necessary to relieve stresses and avoid distortion after machining. There were many ideas on exactly how to do this, some of doubtful merit including urinating on it.
      If seasoning was ever necessary, was this because of the grades of CI available at the time, and possibly their method of production? Therefore not necessary now?
      Does Andrew or anyone else ever season CI castings, i.e.is seasoning relevant nowadays? Especially for the size of castings we are likely to encounter in model-making activities.
      If it is relevant, what sort of temperature/time cycles are we talking about?
      Chas
      #27317
      CHARLES lipscombe
        #467324
        Paul Lousick
          @paullousick59116
          I was advised to leave new castings outside for 2-3 months. The repeated heating and cooling by the sun would releive the stresses. Others suggested to put them at the base of a large fire pit and allow them to cool slowly in the ashes.
          I had plenty of other parts to make and left them to weather outside for about 3 months. Did not have any problems with distortion after machining but don't know if there would have been any if I had machined them sooner.
          Paul.
          #467325
          Hopper
            @hopper
            I have seen one Optimum Chinese-made micro/mini lathe whose cast iron bed bent like a banana after a few months, to the tune of 1mm bend in the top bed ways. Most likely but not conclusively a "green" casting.
            On the other hand I remember acres of unmachined cast iron heads and blocks deliberately left sitting out in the weather for months behind the Chrysler car factory where I served my time.
            #467327
            Bill Pudney
              @billpudney37759
              The first job I had in 'straya was at a company that made mining machinery. The car park was used to season castings, and there were a lot of them. Apparently the "seasoning time" was related to the length of the grass. It was advisable to be really careful when parking the car to avoid hitting a casting.
              cheers
              Bill
              #467329
              not done it yet
                @notdoneityet
                I would expect that ‘weathering’ castings allowed the surface stresses to be relieved, so that later machining did not need to involve large areas of ‘skin’. I would expect modern-day casting operations involve heat cyling at low temperatures to make things like engine blocks (12” to the foot scale) useable in much shorter timespans. Certainly the engine makers want to work with ‘Just-in-Time’ inventories, these days and I doubt the metal is any different than in the old days – just a rush nowadays, rather than allowing larger time frames for castings to mature. Seems sensible to mature castings at the foundry, under controlled conditions, than at the machining point – plenty of spare heat?
                One certainly does not want engine blocks changing shape after the crank bearings have been line-bored!
                #467334
                Chris Evans 6
                  @chrisevans6
                  When I started work in 1963 castings where left out to weather for months and years depending on how many the foundry produced. This kept the foundry busy as they never had to let the furnace die but just kept pouring metal. I was told at the time it was to allow the casting to stress relieve. Fast forward over 50 years and I was asked to machine a batch of castings in my home workshop, I asked the question re how long the castings would be kept for before I received them and the answer was that castings where no longer weathered due to better heat control with the electric furnaces and better quality iron. I did around 90 castings, no chilled skin or blow holes in any of them.
                  #467339
                  mgnbuk
                    @mgnbuk
                    Boxford used to weather castings outdoors for around 6 months. A labourer used to water them daily if it wasn't raining or snowing and, yes, some passing personel did take a leak over them. After 3 months the raw, rusty bed castings were shot blasted and a rough planed top and bottom before being returned outside for another 3 months in the elements. Finally they were shot blasted again, filled and painted before going to the machine shop. The shot blaster was a very violent machine, fully enclosed & used steel slag – it was very effective at cleaning the castings of rust & also probably contributed to stress relief. Good for cleaning up more substantial rusty motorcycle bits as well if you spoke nicely to the operator !
                    The beds for the later geared head machines that were induction hardened did not get weathered – I did ask why & was told that they were heat treated at the foundry to relieve stresses. They did bend when hardened, though, which some attributed to the lack of weathering. A method was evolved that involved torquing down a clamp in the middle of the bed to pull it hollow before hardening. When the hardening pass was completed, the clamp was removed to allow the middle of the bed to rise before finish grinding the bed formation.
                    Can't verify the accuracy of the statement, but I was told that the castings for the Swiss SIP & Dixi machines were dropped into lakes to "weather" in the mud for a period of time.
                    Nigel B.
                    #467340
                    John MC
                      @johnmc39344
                      Many years ago I worked on an "SIP" jig borer that was made in the 1930's. The guy who did the maintenance reckoned the the iron castings were left for 7 years to season before being machined. I initially thought this was a sign of quality. I've no idea how true this is, I'm now sceptical. The castings were, no doubt, of the highest quality, perhaps not needing much seasoning? Surely in the 7 years wait improvements and upgrades to the machine would happen rendering the castings unsuitable? Even back then heat treatments to stress relieve the casting were available.
                      I would guess a good way to season an iron casting would be to rough machine, take the "skin" off, then heat treat to stress relieve.
                      larry phelan 1
                        @larryphelan1
                        A spindle moulder which I bought from a "Well known and respected maker" came with a fence that was so distorted as to be useless. I was obliged to have it machined by a local workshop in order to use it. When I remarked on it to the machine man, he just smiled and shook his head and said "They don't bother to season castings anymore, so this is what you get " That was in 1990, so what,s new ?
                        #467349
                        Paul Kemp
                          @paulkemp46892
                          Even in the late 90's crankcase and bed plate castings at Ruston were 'seasoned' in the manner previously mentioned, left to stand outside initially then part machined and returned outside and then finally brought back in for finishing. Not sure if this appllied to smaller castings like cylinder heads etc.
                          As regards the aggressive shot blasting would help relive stress, crankshafts are shot peered in the fillet radius of journals to deliberately induce a stress in the surface to better resist fatigue failures initiating at the surface.
                          Paul.
                          #467351
                          IanT
                            @iant
                            I don't 'season' my castings as such, partly because they tend to sit around for some time before they get used -and are therefore already pre-aged! wink
                            Seriously, most amateurs work with relatively small castings and they may well have been in the suppliers stock for some time, so I don't think it's a big problem for us – different in a factory where turnaround will be quicker and parts larger.
                            However, I do have a camel-back straight edge casting that I will rough to size and then cycle in the oven for a while before finishing as recommended by the seller. But I won't be doing that for the Hemmingway cast parts I've got in the pipeline. So there may be occasions where it's prudent but generally not essential in my view.
                            IanT
                            #467358
                            Brian Oldford
                              @brianoldford70365
                              If you do use the oven make sure you have due authority from the domestic authorities.
                              Edited By Brian Oldford on 27/04/2020 10:12:19
                              #467362
                              Stuart Bridger
                                @stuartbridger82290
                                Drummonds of Guildford seasoned their machine castings outside. Not sure of the duration though.
                                #467366
                                Circlip
                                  @circlip
                                  Can't understand the reluctance of some to use a domestic oven for tempering PROVIDING you've thoroughly cleaned the item before sticking it in the oven. Used to save any bits I needed to blue till after the Sunday roast was cooked, frugality, oven up to temp, so dangling bits of metal on wires in there no problem.
                                  Regards Ian.
                                  #467367
                                  Nicholas Farr
                                    @nicholasfarr14254
                                    Hi, the graph below will show that nothing metallurgically alters any iron alloys at temperatures below 500 C with exception to some tempering and trying to stress relieve in a domestic oven will just be a waste of energy.
                                    Regards Nick.
                                    Edited By Nicholas Farr on 27/04/2020 10:38:11
                                    #467373
                                    Former Member
                                      @formermember32069
                                      #467374
                                      Ady1
                                        @ady1
                                        Still relevant nowadays IMO
                                        I recall seeing piles of ML7s or Drummond M beds in one photo, they just piled them outside in the yard
                                        Nowadays:
                                        My attention was drawn to our banana shaped cable company pavement covers which were mostly laid in the last 20 years. Some are fine, but some of are damn rocky and it's because they are produced and shipped as fast as possible, so the ongoing inherent issues with cast iron are shipped along with them
                                        #467380
                                        KWIL
                                          @kwil
                                          Part of the problem comes from foundries that kick open the cast just as soon as they can, best left to cool in the sand until easy to handle, earlier ensures you get stresses and chilled areas. Perhaps a good rusting allow the chilled areas to rust away!
                                          #467382
                                          Massimo Dalmonte
                                            @massimodalmonte45801
                                            I remember reading somewhere that, in a factory, big castings were stress relieved by suspending them and having apprentices hit them with hammers (surely the hammers were small and used in way not to chip the castings); it's on a larger scale what is recommended when stick welding cast iron to avoid cracking the weld.
                                            Massimo
                                            #467384
                                            Peter G. Shaw
                                              @peterg-shaw75338
                                              In 2008 I bought a XJ9511 milling machine, which is a clone of the Sieg X2. I think the XJ9511 was made by Real Bull. I bought this machine in the full knowledge that there were likely to be 2 possible problems, one of which happened within a few weeks. (If you remember, in those days there was/are a lot of problems with the plastic gears and the electronics boards on these machines.) What I didn't bargain for was that the table bowed like a banana. At the time I was quite literally a newbie when it came to milling machines – I had never used one, and indeed never seen one on the flesh so to speak, so it was 2011 before I got round to having it reground by Slideway Services, (Brian Caddy?)
                                              On speaking to the proprietor afterwards, he exclaimed that this was one of the worst he had ever come across! So was it lack of ageing? Or something else, although it is difficult to see what else it could be. And before anyone asks, I haven't checked it since.
                                              In fact, as I got to know the machine, I discovered all or most of the problems that afflicted Chinese machinery of that age – casting sand where there should have been none, angle grinder marks on those parts of the slides etc that were normally hidden from sight, etc.
                                              Now, before anyone accuses me of having a rant about Chinese machinery, when I bought I was well aware that there were likely to be problems, but having said that, I learned a lot by rectifying some of them so in that respect I am reasonably happy about having bought the machine in the first place.
                                              Peter G. Shaw
                                              #467385
                                              Anonymous
                                                Here's a link to the NRL article I mentioned:
                                                I think the summary is that stress relieving works but should be done with short, high temperature, cycles. Experiments showed that long term low temperature cycles didn't have much of an effect. This would fit in with the chart shown above by Nicholas. Note that the article is from the US, so temperatures are in Fahrenheit.
                                                I don't stress relieve the iron castings for my traction engines. The larger ones won't fit in my electric furnace for a start. I believe that the castings are made in a small old school foundry using traditional sand casting methods. Thus far I've never knowingly had a problem with movement after machining.
                                                As an aside I stress relieve cold drawn steel and brass sections that are going to be machined asymmetrically. I've had them go banana shaped if not. I've not seen the problem with hot rolled steel, and don't stress relieve, although a while back some posters said they had seen distortion in hot rolled sections.
                                                #467397
                                                  Posted by CHARLES lipscombe on 27/04/2020 02:48:00:
                                                  … believed that seasoning castings made from cast iron was necessary to relieve stresses and avoid distortion after machining. … many ideas on exactly how to do this, some of doubtful merit…
                                                  … what sort of temperature/time cycles are we talking about?
                                                  Chas
                                                  A complicated subject Chas!
                                                  'Cast-iron', isn't one material. Broadly, it's Iron with a lot of Carbon, but in the past it also contained Silicon, Phosphorous, Sulphur, Manganese and other muck. Impurities change the properties of cast-iron significantly, and – before chemistry fixed it – where ore came from mattered.
                                                  Before the industrial revolution top-quality iron came from Sweden because they have large deposits of pure Iron ore plus wood for charcoal, pure Carbon. British ironmasters struggled at first because our ores are mixed and they tried to swap Coal for expensive Charcoal. Unfortunately coal also contains many local impurities. Any success seemed like magic!
                                                  However, with a simple furnace impure cast-irons can be melted and easily moulded. Bit hit & miss, but some areas were able to make useful iron with local characteristics. Scottish iron was better than Lancashire iron for some purposes and vice-versa. Making metal was more art than science.
                                                  During the 19th century improved chemistry found the impurities. Sulphur and Phosphorous are both very damaging and chemists showed how to remove them from ore and coal. Knowledge replacing skill and folklore.
                                                  So, rather than relying on the furnace master, he got a better furnace, materials, and operating guidelines. A large enterprise would have a chemist testing iron during the melt to guarantee consistency. The quality of cast-iron improved enormously. Science displaced guessing.
                                                  Nothing is ever simple! Many jobbing foundries bought in metal, including scrap, and did practical casting work of the cheapest possible kind. Sash-weights can made with almost zero skill using left-overs, perhaps poured cool without bothering to remove slag, and then hosed down to get them out quickly. Today old sash-weights are notoriously poor quality with an exceptionally hard skin.
                                                  Structural and ornamental iron-work and machine parts got more care. However, it's fairly easy to get manual casting wrong. Experts taking care and getting the timing spot on do well, less reliable from the 'B' Team zonked out at shift-end, or when management rush stuff out the door. Blow-holes, slag inclusions, shrinkage, cavities, chilling, heat stresses, etc.
                                                  Stress inside large mouldings due to uneven cooling was a major problem in the 19th century and still can be. Machining stressed castings can cause the whole thing to warp, very bad on a lathe or milling machine! Large complex castings seem more likely to warp than small.
                                                  One solution is to rest precision castings outdoors for a year or three. Fairly obviously, this is another hit and miss method, but – because it's expensive – it became associated with quality. Slow cooling in an oven works too. Peeing on the casting is lore, not science.
                                                  Science hadn't done with cast-iron. Iron was studied to get a solid understanding of how to get specificied results. Repeatable hardness, machinability, toughness, brittleness, stainless, etc. Now thousands of different alloys are available.
                                                  Cast-iron's main advantages are cheapness, moulding, machinability, compression strength, and absorbing vibration: excellent for making machine tools and engine blocks. Having to wait months for castings didn't appeal to early car-makers or US machine tool firms. The US developed cast-irons that didn't need to be seasoned. This is Meehanite, about 30 variants, used in a defined way in an upgraded foundry rather than poured by eye.
                                                  After 1935, seasoning cast-iron hinted the manufacturer was old-fashioned! Unfortunately too often true: in the 1920's buying a British lathe meant waiting a year or more for delivery, while American machines could be had in weeks. Some kind of strange conservatism caused British firms and workers to favour waiting for machines built to last 60 years or more, missing the point that 1995 would be a different world. Move with the times or else!
                                                  Today, cast-iron is all over the place. At one end it's a state-of-the-art engineering material. At the other, crude foundries casting cheapo street furniture, weights, and novelties. In between, almost anything else depending on need. The decision to season or go clever mostly depends on cost. It depends on some mix of foundry capability, run size, and when the customer needs the castings. Seasoning doesn't necessarily indicate quality, rather it's just a tool.
                                                  Warping isn't a problem I've found on my Chinese tools and I doubt they had any special treatment. Although the castings are rough, they're OK where it matters. Anyone found a warped bed on any machine, new or old?
                                                  Edited By SillyOldDuffer on 27/04/2020 12:38:14
                                                  #467744
                                                  CHARLES lipscombe
                                                    My thanks to everyone who replied. As usual there is not a simple answer, it depends on quality of material, foundry technique etc. It does seem however that for the small castings we use in model engineering it is less likely to be a problem than with large industrial components where uneven cooling stresses are more likely.
                                                    I found S.O.D.'s comments particularly interesting (as usual!) especially regarding sash weights. These were often recommended as a source of cast iron for modellers in days gone by. I have personally encountered all known defects of cast iron in a single sash weight. Avoid like the plague!
                                                    Best wishes, Chas
                                                    #467798
                                                    Mick B1
                                                      @mickb1
                                                      In the 80s, CI stage castings for projectors were left to weather for 6 weeks prior to machining – that was the theory but sometimes it was a lot longer. We were late nearly all the time.
                                                      Part of the reason was crazy-tight operation times used to calculate capacity requirements. The smallest projector had IIRC a 14" x 8" stage and was ground on top to a 16 microinch finish and flat within 0.0002" TIR.
                                                      Time Allowed: 3 minutes.
