Rose indexer
Rose indexer
Home › Forums › General Questions › Rose indexer
  • #644837
    john fletcher 1
      @johnfletcher1
      I watched a YouTube on milling, the operator used a Rose Indexer, what a useful tool, does any one know where I can buy one here in UK ?
      #29174
      john fletcher 1
        @johnfletcher1
        #644839
        Bazyle
          @bazyle
          #644842
          Martin Connelly
            @martinconnelly55370
            If you have a mill and a rotary table making one should be easy as well. Possibly why they are hard to find commercially.
            Martin C
            #644843
            Henry Brown
              @henrybrown95529
              Or get a set of Stevenson Collet Blocks? No octagonal option though…
              Stevenson's ER32 Collet Blocks – Arc Euro Trade
              #644845
              Brian Wood
                @brianwood45127
                It is easy enough to do a first pass of 90 degree steps with a square collet, the component just needs a rotation of 45 degrees within the collet to complete the pattern for an octagon on a second pass.
                Edit    Why not go for a 12 step version with the hexagon collet block? Exactly the same logic applies.
                Edited By Brian Wood on 12/05/2023 11:16:32
                #644875
                john fletcher 1
                  @johnfletcher1
                  Many thanks to all respondents, I had thought of making one, but thought if they are readily available and not to expensive I would buy one. Will be another job for next winter, after a summer of hedge and lawn. John
                  #644877
                  DC31k
                    @dc31k
                    A semi-finished version is available here:
                    Indexing Plates The complete Kit
                    I have always liked the idea here:
                    Edited By DC31k on 12/05/2023 13:10:12
                    #644879
                    Hopper
                      @hopper
                      Seems like for hexagons (my most common shape to need milling) you could use a large nut with hole drilled and tapped for the clamping screw.
                      Still trying to get my head around how the Rose Index makes an evenly cut hex, or square or octagon etc when it is mounted well off-centre to the job the way the large hole and grub screw works on smaller diameter jobs. Hard to imagine without having one in the hand. But apparently it must work. Neat idea that seems so obvious once you see it.
                      #644886
                      DC31k
                        @dc31k
                        Posted by Hopper on 12/05/2023 13:17:48:
                        Still trying to get my head around how the Rose Index makes an evenly cut hex, or square…
                        Imagine a square of metal. Superglue it any old how to the end of a piece of bar. If each edge of the square in turn is kept parallel to the mill table below it, the square cut on the workpiece will be correct.
                        Keeping it parallel is fiddly (as the distance keeps changing) so it is easier to keep one edge of the square vertical using an engineer's square. Sure, the stock of the square will slide back and forth on the mill table each time you turn the part, but the blade will always be vertical.
                        It is a good technique to know. If you wanted a seven sided thing, you can just print one out on paper, glue it on the end of your stock and away you go.
                        #644888
                        Hopper
                          @hopper
                          Posted by DC31k on 12/05/2023 13:39:42:
                          Thanks. That makes sense.
                          Less faff that I have been doing with a digital inclinometer on the freshly milled flat. It gets you there but can be fiddly on the small stuff. The bigger hex on the Rose index looks easier.
