Had another dig with "Rail Motor"
Found your drawing error in 3397
ME 3404 p1054 Which reminds
me of one of my recurring faults, specifying too
long guard irons. Those on my “ Isle of Wight ”
locomotive scraped the track, the same happened
with the K.1/1. The No. 1 Rail Motor was even
worse; I shall endeavour to correct this failing.
Happily it is one that can be easily recti¿ed!
There's a pic of the lubricator drive ME no 3405 p1106
Pic of the cyl ports being milled ME3408 p20
ME3433 p63 Don Y0ung’s N0. 1 Rail Motor seen on its first outing
ME3444 p642 The Rail Motor
performed on the ¿rst three occasions in a very
disappointing manner, tmtil it was discovered that
she had already written off her ¿rst superheater.
Whilst renewing the superheater, the blast arrange-
ment was slightly modi¿ed to increase the nozzle
diameter to 1/4 in. This has somewhat curtailed the
pyrotechnic display, as vividly described by D. E.
Lawrence in his M.E. Exhibition report.
ME 3446 has a pic of Don Young steaming his R-M Page746
ME 3478 P1060 The bottom straps project a considerable dis-
tance beyond the pony truck wheels, a feature
which was omitted from the General Arrange-
ment drawing. The reason for this omission
should be clear to builders who have tackled one
of my very early designs. Yours truly had a
failing of detailing guard irons too close to scale,
forgetting that the axleboxes had overscale travel.
Experience with my own No. l Rail Motor cured that failing
after replacing a-t least one sheared
off bolt after every run, the guard irons were
¿nally shortened to a sensible length, clear of the
railhead.
ME 3543 p800
A 5 in. GAUGE “RAIL-MOTOR”
by Anthony T. Vince
The design of the locomotive is basically very
good, but there are some design errors which would
prevent the assembly of the locomotive. For in-
stance the tender being double framed has spacers
between the two frames. The position shown on
the drawing would necessitate cutting a portion out
of the tender wheels in order to get the wheels in—~—
thisof course would stop them going round! There
are other errors of this nature and I would be
pleased to assist anyone completing a Rail Motor
if they would like to contact me.
