projects for kids
projects for kids
Home Forums General Questions projects for kids
  • #24112
    mick70
      @mick70
      #204087
      mick70
        @mick70
        My youngest two kids keep asking to make things we have done loads of wood bits.
        And my boy who is 7 as made a hammer on lathe.
        My 6 yr old girl wants to make spanner.
        Need ideas for other projects please.
        #204091
        I.M. OUTAHERE
          @i-m-outahere
          Good too see your kids are keen on making things !
          I think you need projects that are fairly quick to make and not too complex so i would start with a simple wobbler engine and you could make it from wood or metal.
          If you make such an engine you could then make a very rudimentary traction engine from wood then mount the engine on that and use an airline from a compressor to run the engine ( no boiler ) the drive system is just a rubber band as a drive belt to drive one wheel.
          Ian
          #204093
          Bazyle
            @bazyle
            Are they into Meccano yet? If you get them some they can make spanners and screwdrivers (for old style bolts), plates in plastic and alloy, then move on to pulley wheels.
            #204116
              Things that move are always popular.
              What about roman-style catapults? Use multiple twisted rubber bands to suspend the arm.
              A simple yacht is good project as well, loads of simple designs about and as long as the keel is heavy enough they cannot fail!
              In the old days cranes were popular.
              #204117
              john carruthers
                @johncarruthers46255
                Gyroscope? Clickspring has a couple of videos here…
                Engine Builder
                  @enginebuilder
                  Simple Stirling engine?
                  #204120
                  Ady1
                    @ady1
                    The plans for that clickspring gyro are on this page
                    #204122
                    Gas_mantle.
                      @gas_mantle
                      Posted by john carruthers on 13/09/2015 11:31:58:
                      That gyroscope video was well worth watching, as a beginner I struggle a bit cutting recesses in flywheels, the guy in the video made a tool that seemed to solve all the problems I have when doing it.
                      I've just bought a grinder so it looks like I'll be having a go making a flywheel tool shortly.
                      Peter.
                      #205544
                      Grotto
                        @grotto
                        My 10 year old daughter made a pen.
                        Nothing flash, just a piece of rod bored to take a Bic refil, knurled, and threaded at each end, with brass end caps.
                        She's pretty pleased with it.
                        #205646
                        Ian S C
                          @iansc
                          I'v got a book that you may be able to get ,or something similar, it's called "Metalwork design" by T. Petit, craft education. T. petit was head of the dept of craft and design Aireville Secondary School, Skipton, Yorkshire. I got it about twenty years ago in a second hand book shop in Christchurch NZ. It has a number of types of things to make, from tools, kitchen ware. It generally leaves the construction methods to the children to work out. For example, how many designs can be thought up for a candle stick/holder.
                          Ian S C
                          #205960
                          David Reeves 1
                            @davidreeves1
                            My father introduced me to simple steam turbine using a Tate & Lyle Golden Syrup tin. The turbine was a circle of tinplate about 1.1/2" diameter with about 8 radial cuts which were twisted at the ends to make the blades. A brass wire shaft was soldered through the centre and it was mounted on the lid with a couple of L shaped brackets soldered to the outside of the lid. A small hole was drilled in the lid and a small piece of brass tube soldered in it to make the nozzle to direct the steam onto the blades. Put some water inside, fit the lid/turbine and heat on the gas ring. No need for safety valve as the lid will pop off in the unlikely event that too much steam is produced. Probably doesn't meet the current H&S culture however.
                            #206050
                            Ian S C
                              @iansc
                              I like the Stirling Engine in the video link, might have a go myself.
                              Ian S C
