pillar drill advice
pillar drill advice
Home › Forums › Workshop Tools and Tooling › pillar drill advice
  • #105050
    David G
      @davidg
      Hello
      I'm looking for any advice on a reasonable pillar drill for less than £100.
      The main use would be for wood or metal where I need the accuracy of my milling machine or the milling machine is setup for another task.
      I've been looking around on the Internet and can see brands that I recognise(Clarke, Draper, Record, etc) and others that I've never heard of (SIP, Fox, Sealey).
      I've also looked at what Chester Machine tools and Axminster have to offer. I've ruled out Chester as their range starts at 139+vat.
      Axminster on the other hand have a woodworking pillar drill **Link**, I hope that linked ok and doesn't go under the adverts.., for £86 inc vat. This appears to be an Axminster own brand (lump of metal with their sticker on), has anyone seen one or owns one? There are reviews on their site that give reasonable feedback.
      Axminster also do a range of Engineer's Pillar Drills, cheapest one starts at £131 inc vat LINK, yes i know this would budget stated at the top, but what is the difference to the wood working version other than a rack and pinion to raise and lower the table?
      Are there alternatives that I have over looked ?
      Dave G
      #16944
      David G
        @davidg
        #105052
        russell
          @russell
          well, from the links given there are a few differences. (presimably, you meant to say you DONT need the accuracy..)
          the 'engineer' drill has a lower bottom speed, higher top speed, bigger motor, bigger chuck and weighs almost twice as much:
          therefore you could expect to: drill bigger holes in metal; drill small holes more happily; less flex (i am staggered how much my DP flexes when pushing a drill into steel). and height changing is a necessity, without the rack it would be a real nuisance. (but there are ways of overcoming that using counter balances or struts).
          i've had a quick look at what is on offer locally (Oz) – in comparison your engineering one seems quite low priced, but the ones i've found have bigger motors (say 500-750 W) ,weigh much more, and have 16 speed. mind you, i set mine on a fairly low speed and have never changed it since…
          i suppose it depends on what you want to do with it, how often, and whether you have other plans for the extra budget required.
          -hope this helps.
          russ
          #105056
          joegib
            @joegib
            A few points:
            1. Most of the Axminster reviewers seem to be woodworkers. Their requirements are likely to be less exacting than engineers. Certainly their workpieces are generally less weighty than the stuff we handle. Which brings me to …
            2. The rack — as russell implies, don't regard the rack as a frippery. Say you want to rough bore a biggish lump of metal preparatory to finish boring in the lathe. You'll have the combined weight of the workpiece, maybe a machine vice to hold it safely plus the table weight as well. You'll probably need two hands just to support that lot and position the workpiece centre under the drill point. Where's the other hand needed to tighten the table clamp coming from? The rack is not only a convenience for raising/lowering the table — it acts as a brake preventing the whole lot crashing down the pillar when the clamp is loosened. I'd strongly recommend you don't buy a machine without a rack.
            3. I'd also recommend you try to get to see your potential target buys — either in a tool dealers showroom or at an ME show. A basic test for me in assessing a drill is to loosen any quill lock, extend the drill quill fully, grasp its end and push it back and forth vigorously. If there's any play between the quill and its housing in the drill head, pass on by.
            As regards particular brands I've no recent experience of buying a drilling machine — my first experience with far eastern drill was a disaster! Maybe others can nominate decent machines now on the market.
            Joe
            Edited By joegib on 30/11/2012 06:22:53
            #105058
            David G
              @davidg
              Hi both
              Yes, Russell, there should be a "DONT" with regards to the accuracy.
              thanks for the thoughts and points, I was at the Model Engineering Exhibition at Leamington this year but forgot. I'm not too far from the Axminster Nuneaton so I might give them a call to see what they have on display.
              Thanks
              John Coates
                @johncoates48577
                I'm saving up for a Scheppach but that is way above your budget. I'd looked at the Clarke ones from MachineMart when they have their "Save the VAT" offer but the fact the table was at a fixed distance from the column made me think "how will I do PCD's?"
                The Scheppach head is a long round beam so it can be adjusted for angle and distance. It's under £400 but the delivery is £60. Ouch!
                If we didn't have dreams life would be so dull
                #105083
                Roderick Jenkins
                  @roderickjenkins93242
                  Posted by joegib on 30/11/2012 06:18:59:
                  I realise that what I am about to write is heresey, but here goes anyway: My experience based on a 1/2" capacity hobby drill which I 've had for 20 odd years (a Naerok) is that a bit slop in the quill doesn't really matter – in fact it may be a positive advantage. On the driling machine I drill into a centre pop. The drill bit finds its own centre in the pop. A bit of slop in the quill allows for some misalignement between the job and the drill axis. For the same reason I allow for some float in the drill vice by not bolting it to the table unless I'm drilling something hefty that might pick up and even then I'll usually start the hole before tightening every thing up. If want to co-ordinate drill to accurate locations then I use the mill.
                  I might add that the reason that I chose the Naerok in the first place was that it was one of the few in my price range that had a rack. This, together with the round, pivotting table, makes it very versatile for positioning jobs.
                  cheers,
                  Rod
                  #105086
                  GaryM
                    @garym
                    Hi David,
                    I have the ED16SB from Axminster that you linked to but only bought it about a year ago. I've found it to be as good as I was expecting for a cheapish pillar drill bearing in mind that it was my first proper piece of workshop equipment. The equivalent woodworking drill is the WD16SB which was the same price when I bought mine but now seems to be quite a bit dearer. These two are identical apart from the table and the thing that is not obvious from the pictures is that the table on the woodworking drill has slots that go right through whereas the engineering one has T-slots. I think I might have found the woodworking table more useful in practice but I am a newbie. smiley
                    Gary
                    #105093
                    mgnbuk
                      @mgnbuk
                      The first machine tool we purchased at my previous employment was a floor standing, Sealy branded 12 speed, 2MT pillar dril. It was still in use over 25 years later – still operating with it's original Rexon branded chuck (though the key had been replaced several times). It had a couple of table elevation racks, due to my collegues "forgetting" to lock the table on occasions, but spares were cheap (under £10 IIRC) and available. Belts were a bit more problematic, as they appeared to be non-standard lengths, but one of our bearing suppliers sized replacements using the originals as samples. The machine was used often – frequently pushed to (or possibly beyond) it's limits – in a workshop environment. Should I have a requirement for such a machine for work or home, I would have no qualmes about buying a similar imported machine.
                      Nigel B.
                      #105094
                      colin hawes
                        @colinhawes85982
                        For a general purpose metalworking drilling machine you need the lowest bottom speed and the heaviest machine as the lower speed is better for the larger drillbits and the weight is able to dampen vibration more effectively. Colin
                        #105096
                        WALLACE
                          @wallace
                          Don't forget the ebay option – usually quite a few pillar drills for sale – and can be cheap if you want something that's a bit older. I brought a Progress drill (morse taper 2 with a geared head ) for £120 which seemed quite a good buy – a little worn around the edges but at least the table didn't look like a piece of cheese !
                          Industrial ones are usually always 3 phase but it's not impossible to change – (although you may need a puller to get the pulley off the spindle) plus changing the electrics etc..
                          w.
                          #105109
                          AB658
                            @ab658
                            John C – saving for a Scheppach.
                            Make sure you have played with one before committing. I bought an SIP "radial" floor stander 6 years ago, initially for woodwork. If the S. is similar, the amount of flex in the head, particularly when extended beyond halfway, might cause concern to someone seeking high accuracy.
                            Adrian
                            #105113
                            Grizzly bear
                              @grizzlybear
                              Hi David,
                              For £60 there is a number of drills that would fit the bill. I've just purchased a Clarke Metalmaster S/H for £40 & happy. Saw a Draper, similar spec. in our local tool store Abran Tools @ £59.99 Looked Good. (After I had purchased of course).
                              Regards, Bear..
                              #105114
                              Siddley
                                @siddley
                                I think Colin Hawes has hit the nail on the head – as heavy as possible and with the lowest speed.
                                My own pillar drill is a Clarke ( spit ) that is a weird size. It's only floorstanding if you are a midget and only bench sized if you are a 8ft tall basketball player who owns a workshop with a very high roof
                                Machine Mart is just about the last place I'd buy a machine tool from normally but I bought it in a rush to do one specific job some years ago and didn't mind if it broke afterwards. It hasn't broken and turned out OK. For once. Despite looking robust it has a lot of flex in it when drilling steel at over 12" diameter.
                                #105125
                                frank brown
                                  @frankbrown22225
                                  My drill #1, was a Clarke thing, about £90 in 1980, it was sort of OK, though you could not use the top speed (2500) due to chuck run out. I bought an American lend /lease job second hand for £40, had it since about 1985, still great, and I can still use all the speeds.
                                  For my other workshop, I bought a 16 speed Clarke machine second hand, as good as new for £100 a few years ago. Interestingly, the speed s jump from 720 RPM to 1500 RPM, I do miss 1000 (1/4" diam hole in steel) Else very good value.
                                  Frank
                                  #105128
                                  Sub Mandrel
                                    @submandrel
                                    I have a Clarke pillar dril l that cost about £36 for Machine Mart 12 or so years ago. The bottom of the range one.
                                    It will drill up to 1/2" in steel, even bigger in sheet using a step drill. I have used it with drills smaller than #60 to drill PCBs. The quill wobbles a bit, although you can adjust it to remove slop.
                                    In all that time the chuck fell off once (my fault, drilling big wobbly things) and I had to clean the contacts on the no voltage release switch six months ago.
                                    The one thing I have never had trouble with 9to my surprise) is the table flexing or shifting under pressure.
                                    There is one big fault – the handles keep coming loose, one day I will put thread lock on them!
                                    If I need precision, I use the mill. I rarely drill with the mill. If it blew up today, I would feel I had got my money's worth. If I had to replace it, I would probably buy a slightly larger Clarke one.
                                    #105156
                                    David G
                                      @davidg
                                      Thanks for all the feedback
                                      I had intended to pop down to Axminster Nuneaton after work yesterday to have a look at their tools. They didn't have the ED16SB on display but the next model up so I could get an idea of the difference in quality to the WD13L,
                                      Unfortunately the M1 was knackered and then traffic trough Hinckley to get to the A5 was at a stand still (the mere hint of mist made every one turn their fog lights on while sitting in a stationary queue of traffic), so my original plan to get to Nuneaton for just before 5 left me joining the A5 a little after 5:30. I might try again next week if I can get out on time.
                                      I had tried to steer clear of the Clarke, Draper, etc because of some of the problems to look out for, although from reeding the above not everyone has experienced these problems. My father bought a basic Clarke DP several years(20ish) back and there is only a little play in the quill but the table flexes quite a bit, he lives over a 100 miles away so I can't easily pop round to borrow it.
                                      My father in-law has an old DP, can't remember the make, and the amount of play in the quill was quite astonishing.
                                      I guess in todays world that some of the cheaper tools are made out in the east somewhere and get a different brand sticker on depending who's going to sell them. I have a NuTools miller that looks exactly like a Clarke CMD1225D and a couple of other brands that I cant re-call.
                                      Siddley
                                        @siddley
                                        I looked at the website and it's the CDP401B I have. A bit out of your preferred price range, but I mention it to point out that even spending £270 on a Chinese Communist drill won't get you too much in the way of rigidity. Just so you know what to expect. It hasn't been a bad machine though and it's had some hammer.
                                        I think your premise of wanting a seperate drill press to supplement your mill is very sound, I hope you find something that works well for you
                                        #105208
                                        Sub Mandrel
                                          @submandrel
                                          Looking at the cat, mine is the bottom of the hobby range Ffor someone with a limited but not too-small budget the CDP-10B looks a big step up from the most basic models – rack to elevate the table, MT2 taper so you can swap chucks easily a 370W instead of 250W motor and 12 speeds instead of 5 (although you only really gain a couple of lower speeds).
                                          I can't see any advantages the three most basic 'professional' drill presses have over this one. The main advantages of Siddley's are the worklight, bigger t-slotted table and a much higfher top speed for diddley holes.
                                          I don't personally, think a drill press is as critical as other tools in the amateur workshop and as you have a mill to back it up…
                                          Cornish Jack
                                            @cornishjack
                                            Dave – might be worth looking around for something secondhand. My drill is a Fobco Star and it's built like the proverbial outhouse! Not the easiest to move around and i use a small car jack to raise the head , when necessary. Mine cost me £50 about 20 years ago and, surprisingly, O'Briens still supplied spares a couple of years ago. Cracking bit of kit
                                            Rgds
                                            Bill
