Pickle solution for Gauge 1 Boilers
Home › Forums › General Questions › Pickle solution for Gauge 1 Boilers
  • #107297
    Alan Church
      @alanchurch85600
      What ratio of Citric Acid power to water is best for pickling boilers after silver soldering. Or can anyone inform me of a alternative and supplier, of another product, other than sulphuric acid which would do the job. I am about to build 2 Gauge 1 boilers so small amounts of pickle are the order of the day. any advice would be appreciated.
      Mr C
      #22384
      Alan Church
        @alanchurch85600
        #107299
        Steamshy
          @steamshy
          Hi Alan, I use citric acid, its available at your local supermarket, its in dry form, about one teaspoon to a litre of water should do the trick overnight for you.
          Andy
          #107325
          CuP Alloys
            @cupalloys
            Hell Alan,
            Citric acid supply can be patchy due to the activities of local kids.
            25gm per litre of water seems to do the trick or more simply 100gm into a gallon/4.5 litres.
            If you have difficulties call us.
            regards
            keith
            Edited By CuP Alloys on 28/12/2012 11:17:29
            #107652
            Alan Church
              @alanchurch85600
              Many thanks to Andy and Keith. I have purchase some Citric acid powder, made up the solution and I must say it works a treat.
              Mr C
              #107710
              D.A.Godley
                @d-a-godley
                I have used Citric Acid for some while now ,it being much more user friendly and as effective as alternatives.
                A tip I was given ,so that its life is extended , is to add a splash of bleach into the mix . When stored in washed out plastic milk containers , it keeps good for months without going off.
