Nickel Silver
Nickel Silver
Home › Forums › Materials › Nickel Silver
Viewing 15 posts - 1 through 15 (of 15 total)
  • #848224
    Carl
      @carl48656
      Does anyone know of a supplier of Nickel Silver in bar form, around 3mm x 5mm for example or 0.5 mm wall tube between say 12mm OD to 22mm OD ?  Thanks
      #848256
        M-machine list 1/8″ x 1/4″ which could be machined down.
        https://www.m-machine-metals.co.uk/downloads/Metals%20catalogue.pdf
        #848302
        Chris Gunn
          @chrisgunn36534
          You can try Metalsmith who stock Nickel Silver, find the site, and click through on the ,aterial tab.
          Chris Gunn
          #849455
          Carl
            @carl48656
            Great, thank you for those leads.
            #849494
            Tim Stevens
              @timstevens64731
              It is perhaps relevant to mention (for the benefit of others, as I hope that contributors are clued up) – that Nickel Silver is an alloy which does not usually contain silver, but was used as the foundation of cutlery etc which was silver plated.  So, the name ‘Nickel silver’ was used in the trade to mean Nickel Alloy plated with Silver. I have a feeling that the rules about naming stuff are now tighter.
              Tim Stevens
              #849500
              Roderick Jenkins
                @roderickjenkins93242
                Not quite Tim.  Nickel Silver is effectivley a Nickel Brass alloy – 60% Cu, 20% Zn and 20% Ni or thereabouts.  It looks a bit like silver and, before Stainless Steel, was used as a cheaper, non rusting alternative for forks and spoons. Nickel Silver cutlery was often plated with Silver in which case it became E.P.N.S – Electro Plated Nickel Silver.
                Rod
                #849531
                Andrew Crow
                  @andrewcrow91475
                  Sometimes also know as German Silver.
                  Andy.
                  #849828
                    Just an aside …
                    The Royal Mint uses “Cupro-Nickel” for its [small s] silver coins
                    But I was surprised to discover that the mix varies between the denominations.
                    Could someone please explain “why”
                    Ref:https://www.royalmint.com/collect/collector-resources/designs-and-specifications/twenty-pence-coin-designs/
                    #849840
                    Keith Long
                      @keithlong89920
                      In the case of the smaller denominations probably to keep the metal value of the coin below it’s face value, hence now plated steel rather than copper alloy based. Make them as cheaply as possible while maintaining visual quality and acceptable service life.
                      #849847
                      duncan webster 1
                        @duncanwebster1
                        Back in the early 1700s English silver coins were worth more as silver bullion  than their face value, so they were being exported faster than they could be minted, which put a downer on trade as there was no means of paying for anything. Isaac Newton of apple fame was appointed master of the royal mint to sort it out.
                        They took it seriously, counterfeiting was a capital offence. Might make some of the money market spivs pause for thought
                        #849848
                          Forgive me for asking, gentlemen … but does any of this explain why the composition of the Cupro-Nickel in current use is
                          84/16 for the 20p
                          75/25 for the 50p
                            Don’t worry … ChatGPT has just given me a detailed answer.
                            [ just copy and paste the text from my previous post into its question box ]
                            old mart
                              @oldmart
                              You might try monel tubing it is cupro nickel alloy with high anticorrosive properties, is malleable and ductile. Used on aircraft along with some stainless steels for pressure tubing. Looks more like British “silver” coinage while nickel silver looks slightly yellow.
                              #853011
                              Carl
                                @carl48656
                                Interesting, I’ve not come across Monel before, no zinc in the alloy. I had a quick search though and it looks not as easy to buy small quantities and it is more expensive compared to Nickel Silver.
                                #853015
                                Roderick Jenkins
                                  Monel used to be recommended for boiler stays in model locomotives and was available from the likes of Reeves.  May be worth a look round the m.e. suppliers.
                                  Rod
                                Home › Forums › Materials › Topics
