Physical Object in to Fusion 360
Home Forums CAD – Technical drawing & design Physical Object in to Fusion 360
  • #286222
    steve harvey 1
      @steveharvey1
      I hope someone can point me in the right direction. I want to create a 3d image of a badge so I can use it in Fusion 360 and other programs. I have thought of digitizing it by using a probe and a Mach 3 plugin, I have also considered using photos and VisualSFM to create a 3D image and then use meshworks. If someone has done this before or could recommend another solution I would be grateful. All I want to end up with is the ability to use the final 3D image on the surface of wooden boxes and plaques.
      #21226
      steve harvey 1
        @steveharvey1
        #286299
        Muzzer
          @muzzer
          Sounds as if Inkscape may be one option. Never done it myself but John Saunders has a video showing how it's done. Once it's imported as a vector file you can then do all the extrude / cut etc operations on it.
          Murray
          #286393
          Gary Wooding
            @garywooding25363
            I've used 123DCatch and Meshmixer with good results. They are both by Autodesk and are free to download and use.
            123DCatch will create a 3D model from a series of digital photos, and Meshmixer allows you to edit 3D models. The STLs can be processed in Fusion.
