Photo Etching Question
Home › Forums › General Questions › Photo Etching Question
  • #825723
    Dalboy
      @dalboy
      I would like to have a go at photo etching, I have most of the questions that I wanted to be answered sorted.
      I know that when sorting the photoresist film that you need to use a yellow light, so having the need for the light I dug out my old red photographic light out. Am I correct in saying that would also be suitable for the photoresist film.
      #825736
      Colin Bishop 2
        @colinbishop2
        Do you have Brian King’s book on the subject.
        https://www.abebooks.co.uk/9781854862372/Photo-Etching-Workshop-Practice-Series-1854862375/plp
        Brian was a good friend of mine and sadly missed. He used his photo etch techniques on many of his award winning model ships at the ME Exhibition.
        Colin
        #825740
          Editor Neil in his article used UV light
          Quick look at the above mentioned book and that also says UV
          #825753
          Dalboy
            @dalboy
            Thank you both for the response, but I feel you have misunderstood the question I am referring to, when you apply the resist to the metal before the UV treatment as it can not be applied in natural light.
            Yes I have the book, but it mentions a yellow light when applying the resist.
            I also have a UV light on order for exposing the film to the printed sheet when transferring the pattern to the resist
            #825754
            Roderick Jenkins
              @roderickjenkins93242
              I suspect Dalboy is referring to handling the photosensitive film prior to exposure to daylight/UV.  I’m sure red-light will be fine, even less of the blue spectrum than the old yellow lights for dark room work.
              Rod
              edit – crossed post !
              #825759
                Ah, book says “subdued light”, Neil just says avoid sunlight or getting close to fluorescent light.
                #825761
                Dalboy
                  @dalboy
                  Rod
                  Yes that is what I was trying to say thank you for putting in a simpler way to what I typed
                  I would rather play on the safer side of things to avoid it going wrong. Mind you, what sunlight do we get this time of year
