Peristaltic Pumps
Peristaltic Pumps
Home › Forums › General Questions › Peristaltic Pumps
  • #206119
    Speedy Builder5
      @speedybuilder5
      I am looking for a supplier of a length of silicon rubber tubing for a peristaltic pump 12 mm OD x 1.5mm wall thickness. The only suppliers I have found so far seem too expensive (£24 for a short length). Any ideas chaps and ladies.
      BobH
      #24140
      Speedy Builder5
        @speedybuilder5
        Replacement tubing
        #206121
          9mm bore towards bottom of this page £21 cheaper
          #206123
            If 13mm 2mm thickness tube will do, the bay has it for £6.94 a metre.
            Vic
              @vic
              I've seen a few peristaltic pumps before but nothing using anything near as large as that size tube before, what's it for?
              #206127
              DMB
                @dmb
                £24 for a short piece of tube?
                Sounds like normal price to the NHS! Plenty more money where that came from.
                #206128
                  Vic, they do make big ones
                  #206130
                  martin perman 1
                    @martinperman1
                    I change peristaltic tubes on a regular basis as they are used in dosing pumps which run 24/7, plain silicon tube doesnt last long as it can stick together inside and it splits.
                    PM me and I maybe able to find you what you need from a slightly different material.
                    Martin P
                    #206131
                    Boiler Bri
                      @boilerbri
                      Bri
                      Model aircraft use the tube for fuel lines etc try a model shop
                      #206146
                      Roger Head
                        @rogerhead16992
                        It's important to know exactly what is being pumped, anything associated with foodstuffs, pharmaceutical products, etc obviously have all sorts of regulations. However, I would have expected a) the OP to have stated if it were for such use, and b) to have known where to get it i.e. not by asking on a model forum.
                        Even so, there is still an enormous range of possible constraints. It would be well worth checking out the Tygon range of products (Saint-Gobain), which includes specific applications for peristaltic pumps. The catalogue can be found at
                        http://www.piedmontplastics.com/media/275605/tygon%20catalog%20t-110r%208-06.pdf
                        Lab supply companies can usually supply Tygon, but typically it's not cheap (at least here in Oz).
                        Roger
                        #206153
                        Speedy Builder5
                          @speedybuilder5
                          Thanks as usual to all responders. The tube is for an older Swiss made pump connected to a Parvalux geared motor with speed control which seems ideal for a low volume coolant pump for my mill. The setup will be similar to my old pump (which gave up the ghost after 6 years of abuse !!) but this time I will pre filter the coolant – any ideas on that?
                          Bob H
                          #206175
                          Ian S C
                            @iansc
                            A place that may have suitable tube is a garden shop that has parts for a liquid lawn fertilizer trolley.
                            Ian S C
                            #206936
                            Speedy Builder5
                              @speedybuilder5
                              Thanks Neil, your reference for the tube came up trumps and postage to France was more than cheap.
                              BobH
                              #206947
                                Thanks for the feedback, Bob.
                                #206958
                                David Colwill
                                  @davidcolwill19261
                                  Hi,
                                  I have a load of 10mm x 2mm bore bright red, I know it is silicon tubing and believe it is medical grade. If you could make that do you can have a couple of meters FOC.
                                  David.
                                  Edited By David Colwill on 07/10/2015 15:23:24
                                  #206971
                                  Speedy Builder5
                                    @speedybuilder5
                                    thanks David C, but I have bought and received 12mm x 8mm bore from Advanced Fluid Solutions. Good price and spot on delivery – happy customer.
                                    BobH
