Parting hexagon bar
Parting hexagon bar
Home › Forums › Beginners questions › Parting hexagon bar
  • #819181
    old fool
      @old-fool
      I’m very much a newby. I learned what I know about turning during “lock down” with lots of help from Harold Hall’s “little green book” as well as on-line sources. not least “Blondie Hacks” who really stresses safty issues.
      To cut to the chase. I’m currently making an adapter for a power steering pipe (the new ones have different ends). I’m using 19mm mild steel hexagon bar so it can be tightened in with a spanner. My question is:- can I use a parting tool to cut it to length or would it be better to saw it to size then face it up square? The dilemma is that at the start of the cut it will be very intermittent until I get below the corners of the hexagon.
      I use a rear toolpost so I’m pulling the tool in from the back, not pushing it from the front. Any thoughts from the more learned gentlemen appreciated.
      Bob
      #819185
        I don’t find hex or square to be a problem with a front post, maybe run a little slower than I would with round until the tool is cutting solid metal. Surface may want a clean up skim anyway so you could just as easily saw it off.
        #819198
        bernard towers
          @bernardtowers37738
          Try putting a v into the hex first till the width exceeds the parting tool, that should help. The v tool doesn’t seem to vibrate as much as the parting tool.
          #819217
          larry phelan 1
            @larryphelan1
            For what it,s worth, I agree with Jason, the bandsaw first then just a simple skim to clean up. As it happens I had to make a number of unusual thread nuts recently for a local and I found it was quicker and simpler to employ saw and face tool, forget about parting off and all its hassle.
            #819221
            Julie Ann
              @julieann
              Parting off brass and steel (including stainless) hex works just fine at normal parting off speeds and feeds with front toolposts, HSS tooling on the repetition lathe and carbide inserts on the centre lathe. The finish is normally good enough not to need further machining.
              Best advice is not to over think things.
              Julie
              #819226
              Clive Foster
                @clivefoster55965
                I keep a really sharp, double ended flat top symmetrical 45° round nosed tool in one QC holder for chamfering, edge breaking and fine cut cleaning up of not quite good enough surfaces. So simple and so useful.
                If I’m parting off hex bar intended to be a nut of some description I run the round nose in until there is a chamfer all round across the flats, so a little deeper than the hex edges. Then I run the parting tool into the middle of the round end Vee. No issues with getting going on the sharp hex points and, after parting off, there is nice, blunt, chamfered edge just like a normal nut. Simply parting off always leaves a painfully sharp end to the hex corners.
                #819235
                not done it yet
                  @notdoneityet
                  I would say that it depends greatly on the quality of the parting tool.  Cheap, and may well get blunted (if HSS) or shatter/chipped (if cheap TC).
                  #819244
                  Vic
                    @vic
                    I parted some mild steel Hex bar the other day with a T shaped HSS blade. As expected it cut fine.
                    #819261
                    Andy Stopford
                      @andystopford50521
                      Mild steel hex is usually a free-cutting grade, and machines very easily indeed, including parting off – chamfer it first ‘cos it looks better that way.
                      #819269
                        Beauty is in the eye of the beholder. I mostly make single chamfer nuts ‘cos they look right on old engines. 😉
                        #819274
                        Andy Stopford
                          @andystopford50521
                          I should have made myself clearer – I meant the top face…or do I mean the outer face…do I even know what I mean…do I mean anything at all*…?
                          *Existential question
                          #819278
                          Nigel Graham 2
                            @nigelgraham2
                            I do take the initial cutting at low speed and gentle feed until there is an appreciable arc between each flat.
                            One problem I suspect with intermittent cutting on lathes with screw-on chucks is the hammering action tightening the chuck still further.
                            If we reverse the process, making polygonal features on essentially cylindrical items, I use a different approach where possible, especially for batches of items. Here I cut grooves to the eventual A/F diameter at the parting-length, and add any chamfer at that point, then mill the flats before parting-off. It means two machine transfers but since I am more likely to make five rather than five hundred parts, that’s not a great problem. If the maximum diameter fits the lathe spindle the intermediate stage is a rod with a series of grooves round it. The end effect is that the parting-off is always on cylindrical stock.
                            #819470
                            Howard Lewis
                              @howardlewis46836
                              Parting hexagon or square material means that thing hammer until below the corners, so a slow steady feed is advisable, with plenty of lubrication, and a fairly low speed.
                              A rear toolpost makes life a little less fraught with regard to the risk of dig ins or broken blades.
                              Sawing by hand will be hard work, but facing and chamfering will less frightening.
                              #819493
                              Richard Simpson
                                @richardsimpson88330
                                I think when we are new to something we tend to try to look for the silver bullet for any unknown situation that will automatically solve it.  Unfortunately there are frequently too many variables to resolve with a single simple answer.
                                What experience will eventually teach you is to ‘feel’ when you are machining.  You can set the revs for the material and the diameter but then the feed is up to you and that is determined by the feel of the handwheel.  Only you can feel as you slowly rotate the handwheel whether it is too much or just right.  Too high a feed and the chatter will rattle the bed, saddle, slide, and your teeth and eventually break the tool.  Feed it slowly enough so that everything feels nicely under control.  As Jason mentioned earlier, you will find that initially the required feed is slower when the chatter is more noticeable but the feed can increase as the depth increases.  It is all governed by the feel.
                                #819495
                                bernard towers
                                  @bernardtowers37738
                                  The idea I gave earlier of the v tool is that the hex chatter is reduced as the pointed part of the v is very narrow so reaching a completely round piece of material is achieved with much less noise and vibration, so then you can carry on with a conventional parting tool.
                                  #819511
                                  Julie Ann
                                    @julieann
                                    On my centre lathe I part off using power feed. So feel doesn’t come into it, just knowledge of what feeds and speeds work.
                                    Carbide parting off inserts need a minimum feed, otherwise they chatter badly and break. I use a minimum feed of 4thou per rev. If I need to machine an accurate groove, sneaking up on dimension, I use a HSS toolbit ground to look like a short parting off tool.
                                    Julie
                                    #819522
                                    duncan webster 1
                                      @duncanwebster1
                                      Slight digression. My memory says that some very clever lathes could turn a hexagon onto round bar. Of course I’m getting old and might be doiting, but anyone know anything about this?
                                      #819531
                                        I’ve seen the machines working when we used to do work in Monument Tools factory. There is a rotating head with a cutter that is timed to the spindle depending on how many flats you want for say a square or hexagonal key the cutter would rotate 4 or 6 times faster.
                                        #819535
                                        duncan webster 1
                                          @duncanwebster1
                                          Sounds like a challenge for the CNC men, way too clever for me. My gut feel is that cutter diameter and hex AF will be related, but I could be wrong.
                                          #819542
                                          old fool
                                            @old-fool
                                            Thanks to all above. In the end I cut it in the chop-saw (a bladed one not an abrasive), since as Jason pointed out the job needs to go back in the lathe for further work on the other end. As it’s a pipe fitting adapter both ends are different. I’m at the exiting stage of my career as an amature turner, where every project has some prosses I’ve never tried before. Sometimes it’s a case of sitting down and thinking it through and sometimes it’s a case of ask someone, Cue the forum. Especially when there’s the chance of it going unpleasantly wrong!
                                            Thanks all Bob
                                            #819552
                                            Julie Ann
                                              @julieann
                                              On duncan webster 1 Said:
                                              Sounds like a challenge for the CNC men, way too clever for me. My gut feel is that cutter diameter and hex AF will be related….
                                              Simple enough on a CNC lathe with active tooling. The important thing is correct synchronisation between work and cutter spindles. I am sure there used to be commercial polygonal attachments for conventional centre lathes but can’t for the life of me remember the manufacturer. Something like Chatwin? Here’s a video of a home made system:
                                              https://www.youtube.com/watch?v=oCFfvmREacA&t=1017s
                                              Julie
                                              #819553
                                                That is much like I remember seeing, drive shaft came out of the headstock to drive the tooling and I suspect the gearing was also in the headstock. Quite a large diameter cutting tool flying round.
                                                No CNC in there workshop in Balham but that was back in the early 90s, posh flats now. They also had cam opereated lathes with long bar feeders for the repetative items.
                                                #819611
                                                duncan webster 1
                                                  @duncanwebster1
                                                  If JARadford were still around there would be an attachment for an ML7 on its way. Geometry is fascinating, drive the cutter with a stepper motor and it seems no more difficult than arranging an ELS
                                                  #819901
                                                  Howard Lewis
                                                    @howardlewis46836
                                                    Slow and steady is the safe way, with a sharp tool on centre height. Rush the feed and, particularly on the flats and a dig in or broken parting blade is likely.
                                                    Saw and then face is the safest option, until you are confident in the tool, machine and operator
