Parting blades profile.
Home › Forums › Workshop Tools and Tooling › Parting blades profile.
  • #463399
    Manofkent
      @manofkent
      Like many here I use a parting tool holder and separate blades such as the 5" long blades sold by RDG and other suppliers.
      I want to make my own tool holder. Can anyone tell me the blade side angles please. The blades are slightly wider at the top, and narrow to the bottom.
      Many thanks.
      Manofkent
        @manofkent
        #463404
        Joseph Noci 1
          @josephnoci1
          Not sure all blades have the same taper –
          Measure the thick and thin parts at the edge, measure the length ( or width if you will) of the taper section, and a bit of Trig will do it – or Google for trig calculators if your trig functions are defunct..
          Joe
          #463408
          Gary Wooding
            @garywooding25363
            If the width of the top is T, the width of the bottom is B, and the height is H, then each side angle is …
            Arctan( (T-B)/2*H)
            eg. If T = 2mm. B = 1.5mm, and H = 12mm, then each side angle is the angle whose tangent is…
            (2-1.5)/2*12 = 0.5/24 = 0.0021
            The angle that has this tangent is Arctan(0.0021) = 1.2 degrees.
            #463411
            Clive Brown 1
              @clivebrown1
              IIRC, the GHT rear toolpost design did not angle the side of the slot. He instead put a couple of small, (6BA?), skt. hd. grub-screws fairly low down to act as adjustable stops. Could be worth copying.
              The other feature was angling the top and bottom edges of the holder slot to match the typical "Eclipse" parting -off blade. This was probably around 4 to 5 deg.
