Posted by Matt Stevens 1 on 07/05/2021 13:13:58:
He said the website claims 2mm relief but in reality it is 4mm which is just enough to accommodate 1/2" tooling.
If the above it true, it makes for an east fix for any Myford 7 series….however i am still wary because i don't understand why they wouldn't just sell that one kit for all lathes promoting its advantage on the 7's.
Myford/RDG would know for sure, but I suspect it's because they don't want to commit to anything outside the lathe's specification.
As Myford Super 7 lathes weren't designed or intended to be used with 1/2" tooling any customer who wants to do that is outside the normal support envelope.
For legal reasons suppliers are generally unwilling to take responsibility for modifications that might not work, especially if the amount of relief available on a bought in ML10 QCTP might vary from batch to batch.
Is there an engineering reason for wanting to fit oversized tooling to a small lathe? Though my Chinese lathe would take 1/2" shanks, I use 12mm. I've no desire to upgrade the machine to take 15mm tools. Expensive to do for not much return, if any.
As big knives are clumsy on small jobs I'm as likely to turn with 10mm tools as 12mm, and often get into small gaps with 8mm. If the work really requires 1/2" tooling, I suggest buying a bigger lathe. Then the whole machine is scaled to take the strain, not just the oversized cutter.
