Myford super 7 Tailstock Spindle Damage
Home › Forums › Help and Assistance! (Offered or Wanted) › Myford super 7 Tailstock Spindle Damage
  • #421498
    Carl
      @carl48656
      Hello all,
      The MT2 spindle bore in my tailstock has some damage i can feel, has anyone any idea of how to best clean it up ?
      Has anyone any experience of using a MT reamer or any other way that proved successful ?
      Thanks
      #33429
      Carl
        @carl48656
        #421499
        Martin Connelly
          @martinconnelly55370
          I have cleaned one up (not on a Myford) with a reamer. Held it in the 4 jaw to get best possible concentricity of the shank and checked the tip was running true using the centre drilled hole. kept everything locked or pinched to minimise snatching and turned the chuck by hand to take off the minimum necessary to give a good surface. I was only removing raised high spots and leaving the main bulk of the spindle untouched.
          Martin C
          #421518
          Brian Wood
            @brianwood45127
            Hello Carl,
            I too have cleaned up the morse tapers on tailstock barrels, but I adopted a much gentler way of going about it
            I gripped the tang end of the correct size reamer in the bench vice in one instance and pushed the barrel onto it while rotating it by hand. You can 'feel' the cutting that way. I haven't measured the result as the lathe is being refurbished but taper shank drills fit with a nice 'kerthunk' noise and grip properly
            In the second case, a 3 MT version, the tailstock barrel [18 inches long and heavy] was gripped via a cloth in the vice and the reamer turned by hand in a big tap holder, using the tang gripped between the jaws of the tap holder. Later measurement on a precision bar at 5 inches from the mouth of the barrel gave a run out of under 0.001 inches and again there was the satisfying 'kerthunk' noise on fitting drills
            #421868
            Carl
              @carl48656
              Thank you for the replies, sounds like good advice on controlled use of the MT reamer. I think i will give it a go.
              Carl
              #421881
              KWIL
                @kwil
                It may well be that you have an "piece" of swarf imbeded, just a light touch with the reamer.
