Myford ML4 to ML7 nose thread adaptor
Home › Forums › Workshop Tools and Tooling › Myford ML4 to ML7 nose thread adaptor
  • #97745
    Dean Godfrey-Cooke
      @deangodfrey-cooke74440
      Hi All
      This is my forst post on the forum, hello!
      I'm new to Lathes and have picked up a cheap-ish ML4 in decent condition.
      The first thing I did was turn down the collar on the toolpost to take a quick-change holder, that was easy enough, though a bit complicated trying to hold the tool with the toolpost in the chuck, luckily I had a bunch of bolts hanging around, plus a little grim determination.
      Now I'd like to swap out the 3-jaw Bernerd chuck. It works OK but a couple of the teeth are broken on the jaws and it only has the inside jaws, wich just don't open enough for some Alu stock I have.
      My options seem to be:-
      A) Fit a new chuck to the current back plate, turning down the spigot and drilling some new holes
      B) Fit a new chuck and backplate, machining the new backplate from scratch.
      C) Make an adaptor to fit a standard threaded ML7 chuck and backplate already machined and mated.
      Option A isn't bad but keeping the Bernered would be ideal as I could go 4-jaw independant with the new one, also the spigots are slightly different.
      B is do-able but probably beyond my current skill level
      C would be the ideal as I could use both cucks easily and can fit new, Myford threaded chucks/faceplates etc easily later on.
      So My questions are; Is this possible? Easily acheived? Would Steel do it or would it need to be iron? Hardened Steel? Could anyone with an ML4 and a spare hour knock one up for me :D?
      Cheers
      Dean
      #16876
      Dean Godfrey-Cooke
        Converting the 7/8 9tpi to 1-1/8 12tpi Spindle Thread
        #98250
        Dean Godfrey-Cooke
          WOW, I really didn't think this would be that difficult, ah well, back to the Ol' drawing board cool
          #98253
          MICHAEL WILLIAMS
            @michaelwilliams41215
            Hi DGC ,
            There are really only two credible solutions to your problem :
            Use the existing spindle and make all chuck backplates and other fittings new to suit .
            Make a new spindle with Myford spindle nose and use standard Myford backplates and fittings ..
            There is no credible solution using an adapter .
            The easiest and best of theses solutions is to keep existing spindle . Making new chuck backplates is not difficult .
            To bore the accurate spindle register you will need to first make a gauge which is a short piece of bar turned to EXACTLY the same diameter as existing spindle register . You may need to have more than one go but you'll soon have success . For the thread I recommend that you basically screwcut the thread but use a bought tap to actually finish to size – it'll be a standard thread and people like Tracy Tools will probably find you a tap .
            So with backplate casting mounted in chuck or on face plate boss outwards :
            Face off end of boss , drill and bore the through hole undersize and then bore core size for thread .
            Screwcut thread and finish with tap (tap may not have enough clearance to go right through to back but cut as much as possible in place and if needs be finish later ) .
            Very carefully bore the spindle register using your pre-made gauge . Aim to have gauge a very close fit in bore .
            Optionally finish machine the other surfaces at boss end of backplate .
            Mount partially made backplate on actual lathe spindle and turn the chuck register and and other surfaces .
            Take great care with all the final sizing of spindle and chuck registers – take very fine cuts and don't go full length in one go – try a very little bit at the end of register for fit each time and then turn the full length as appropriate .
            The above is a good way of making backplates if you have limited experience but there are better more high precision methods which we can talk about another time if you want to .
            NB : Its the spindle register that does the alignment of chuck and backplate to spindle . The thread would ideally be accurate but to a definately lesser degree than the register .
            Ask me any questions you would like .
            Regards ,
            Michael Wiliiams .
            #98254
            Ian S C
              @iansc
              I don't know the spindle nose sizes of the two lathes, but if there was enough difference you could bore and thread a steel cylinder to mount on the smaller lathe, then screw cut a thread on its outside. With this piece loctited in place, would this be the answer? Ian S C
