MT3 Imperial and MT3 Metric differences
Home › Forums › Beginners questions › MT3 Imperial and MT3 Metric differences
  • #109772
    Scottmk1
      @scottmk1
      Hi I am looking to buy a Sieg SX2 Plus mill to accompany the Myford lathe I have. I see on the Arc Euro website that they do a MT3 spindle in both metric and imperial, is it just the drawbar threads that they are refering to or is the something else?
      #6537
      Scottmk1
        @scottmk1
        #109783
        joegib
          @joegib
          I rather think the references to metric/imperial relate to the slide leadscrews and dial graduations, this being the major consideration when buying a new machine.
          Joe
          #109784
          Scottmk1
            @scottmk1
            Hi Joe, Thanks for your reply. I think you may well be right.
            #109793
            Steambuff
              @steambuff
              The drawbar thread is Imperial on a Imperial machine.
              colin hawes
                @colinhawes85982
                It is the drawbar thread that's different. You can have one of each drawbar if you accumulate a mixture of fittings. Colin
                #109796
                Scottmk1
                  @scottmk1
                  Thanks for the replys and clearing that up for me.
                  #110123
                  Scottmk1
                    @scottmk1
                    Ok, after having another look at this size of mill and what I would like to do with it, I think I am going to try and get one that can accommodate larger work pieces.
                    There was a Warco MD30B just sold on ebay, and that seemed and ideal size, is there anything on the market of this size under £1000?
                    #110146
                    Nicholas Farr
                      @nicholasfarr14254
                      Hi, I agree with Joe that the reference is to the the slideways and the quill dial movements. MT3 is MT3 whatever the thread in the end is, you just need a drawbar to suit which thread you have in your MT3 tooling. I have two or three different ones, but the can all be used on my Imperial mill.
                      Regards Nick.
                      #110189
                      Sub Mandrel
                        @submandrel
                        As Nick says, you will probably end up needing one of each. A length of studding or even a long bolt, cut to length can serve if you get stuck.
                        A large chuck with an MT3 arbor and metric drawbar came with my mill. I usually buy/make accessories with imperial drawbars so I've made an imperial self-ejecting drawbar. One day I WILL get around to making a metric drawbar for it!
