ML7 Swing Head assy
ML7 Swing Head assy
Home › Forums › Manual machine tools › ML7 Swing Head assy
Viewing 2 posts - 1 through 2 (of 2 total)
  • #506791
    Russell Spencer 3
      @russellspencer3
      Good afternoon,
      I have been using an old ML7 for sometime and have decided it needs some TLC after a motor failure. In the process I dismantled the swing head assy to find the countershaft and oilite bearings pretty worn.
      So the quick question is – is it possible to make your own (it is the old style without woodruff keys) or do I need specially hardened steel and are there third party oilite bearings that can be machined/altered to suit.
      Also – does anyone know the thread size for the 2 x adjuster screws which sit onto the eccentric shaft to adjust belt tension?
      Thanks in advance.
      Russ
      #14085
      Russell Spencer 3
        @russellspencer3
