mini turning
mini turning
Home › Forums › Beginners questions › mini turning
  • #9619
    Roger Hulett
      @rogerhulett83124
      #404607
      Roger Hulett
        @rogerhulett83124
        I have a 70mm x 5mm brass rod. I need to turn this down to 3mm. At one end there needs to be a 45degree angle to take the rod from the turned 3mm to the original 5mm. I have a 1939 South Bend 9" a small Pools horizontal mill. Rotary Table, Vertical slide. Pillar drill
        Advice on the correct procedure to carry this out will be very much appreciated.
        #404608
        Former Member
          @formermember19781
          #404615
          mechman48
            @mechman48
            +1 for drilling, solder then bend, easiest way as Bills method above.
            George.
            #404617
              How long is the 3mm section?
              If it is long do you have spare material for tailstock support?
              #404618
              Roger Hulett
                @rogerhulett83124
                Sorry, did not explain myself correctly. I should have said the 3mm diameter will TAPER
                out to the 5mm diameter.
                #404626
                Former Member
                  @formermember19781
                  #404639
                  Samsaranda
                    @samsaranda
                    Sharp tool and required angular offset on the tool holder, with 5mm brass rod you wouldn’t need any support or steady, I have made fuel control needles in smaller diameter brass without problems, you need a sharp tool and shallow cuts.
                    Dave W
                    #404647
                      Posted by Samsaranda on 11/04/2019 17:23:24:
                      I would if the taper is over the full 70mm length, a question that has not yet been answered.
                      Edited By JasonB on 11/04/2019 18:17:57
                      #404648
                      Emgee
                        @emgee
                        Roger, if you only need a short length of 3mm diameter use a facing & turning tool which is ground to 45 deg angle to the lathe axis, either take 1 x 1mm DOC or a series of cuts to achieve the 3mm diameter, at the 1mm DOC you will have your 45 deg transition from 3-5mm.
                        Emgee
                        #404785
                        Former Member
                          @formermember19781
                          #404786
                            If the tape angle is 45 degrees as stated, then an angled tool will do the job.
                            Mount 5mm rod in the mill, set up a tool in the vertical slide attached to the table and do the job with a single cut.
                            #404787
                            duncan webster 1
                              @duncanwebster1
                              Posted by Neil Wyatt on 12/04/2019 17:51:55:
                              why use a milling machine when the OP has a lathe?
                              #404878
                              Roger Hulett
                                @rogerhulett83124
                                OK everyone,Thanks very much. Job done. 45degree tool did the job.
                                #404883
                                Former Member
                                  @formermember19781
                                  #404893
                                  Ian S C
                                    @iansc
                                    A rough sketch on a bit of paper with a pencil can be useful.
                                    Ian S C
                                    #406247
                                    Roger Hulett
                                      @rogerhulett83124
                                      It's all I can do to work a lathe and type letters on a computer Asking me to take pictures or draw sketches and post them…….well. …………..Now …………… If my great grandson was here…….. no prob.
