Milling vices
Milling vices
Home › Forums › Workshop Tools and Tooling › Milling vices
  • #223024
    Mick Henshall
      @mickhenshall99321
      I have 2 milling m/c's + a 6"shaper, I have a 100 mm wide vice which I use a lot on the mills and have decided to buy another vice but can't decide on another 100mm vice or an 80mm one which would be better to use on the shaper. The 100mm looks a bit ungainly on the shaper but the extra capacity of the larger vice is tempting,what would you do?
      Mick
      #17977
      Mick Henshall
        @mickhenshall99321
        #223025
        Ady1
          @ady1
          Normally I would pick the bigger one. What shaper do you have?
          A shaper can usually take some hefty roughing cuts and easily deals with tough jobs a lathe would hate, hence the bigger the better in most circumstances
          You can also make your own vices on a shaper because they excel at flat surfaces, a solid steel vice can last a lifetime
          Edited By Ady1 on 29/01/2016 11:42:25
          #223026
          Mick Henshall
            @mickhenshall99321
            The shaper is home made with a 7" × 5" table, Iam just fitting the slides to it, there will be a support fitted to outer end of table so should be pretty stiff, the mills are horizontal Adcock/Shipley and a Warco WM14 if the vice was fitted to one I would often need to fit it on the other which can be a pain,I suppose ideally I couuld buy 2 more vices but cost is a consideration
            Mick
            #223027
            Mick Henshall
              @mickhenshall99321
              Mick
              #223028
              Mick Henshall
                @mickhenshall99321
                Apologies I appear to have posted twice
                Mick
                #223029
                Nick_G
                  @nick_g
                  Have a nosey at the excellent range of milling vices of various sizes stocked by ARC Eurotrade. IMHO very nice for the money.
                  At the prices they are not worth bothering constructing your own unless it's for the personal satisfaction of "I made that" which by default a lot of members here can relate to. smiley
                  Nick
                  #223030
                  Mick Henshall
                    @mickhenshall99321
                    20150826_122414.jpg20150826_122430.jpgHere are some some photos taken early on in the constructio,I have progressed since
                    Mick
