Milling alluminium
Milling alluminium
Home › Forums › General Questions › Milling alluminium
  • #487314
    petro1head
      @petro1head
      Quite often i get a build of of alloy on the cutter and have to stop the job to remove the build up.
      so would a dab of thread cutting oil help, or something else.
      don't want to flood cool due to mess
      #27533
      petro1head
        @petro1head
        #487315
        Martin Kyte
          @martinkyte99762
          Paraffin or WD40.
          regards Martin
          #487316
          petro1head
            @petro1head
            Brill, thanks
            #487320
            not done it yet
              @notdoneityet
              I’ve just sent you a PM.
              #487322
              Martin Connelly
                @martinconnelly55370
                Avoid coated cutters as well.
                Martin C
                #487338
                Eric Cox
                  @ericcox50497
                  Make sure your cutter is sharp.Yesterday I had to take a centre punch and hammer to mine to remove the build up.
                  #487348
                  mechman48
                    @mechman48
                    + 1 for WD 40.
                    George.
                    #487352
                    Bill Pudney
                      @billpudney37759
                      +2 for kero or WD40. My preference is for kero. Experience with WD40, in other applications suggests that WD40 leaves a sticky gooey mess, as a result I haven't used it much as a cutting aid. It is however brilliant at water displacing. Kero, or paraffin is very good on al. alloy, and as others have said, uncoated really sharp cutters work best.
                      best of luck!!
                      cheers
                      Bill
                      #487415
                      mark costello 1
                        @markcostello1
                        If You can buy cheap penetrating fluid at auto jumbles etc. it works well.The cheaper the better.
