Meehanite.
Meehanite.
Home › Forums › General Questions › Meehanite.
  • #22189
    Raymond Anderson
      @raymondanderson34407
      #96933
      Raymond Anderson
        Hi All,
        I have been trying to source a piece of Meehanite plate in size 210x130x30 but no joy yet ,does any one know where I can obtain it.
        Usually I get my steel free ,but the brothers employers don't use Meehanite or any type of cast iron If I need anything other than EN24T, EN16T or the like then I use M Machine but no luck with the Meehanite/ Cast iron.
        Raymond.
        #96938
          Does it have to be plate? could you use a 30mm slice off the end of a rectangular bar in which case College Eng may be able to help.
          J
          #96940
          Raymond Anderson
            Hi Jason,
            I should have mentioned that I also tried College engineering ,but they replied that they do not stock anything that size.
            Raymond.
            #96943
              Mallard say they do plate or you could get it out of a billet of 250mm dia.
              #96945
              MICHAEL WILLIAMS
                @michaelwilliams41215
                Excellent company and no specific minimum order size .
                As is usual with this type of supplier there is an excellent website but no catalogue as such – you Email your requirements and they will quote back .
                Be prepared for a shock on price though .
                Michael Williams .
                #96946
                Raymond Anderson
                  Thanks Jason and Michael, I will e-mail both firms and see what develops
                  Raymond.
                  #97010
                  Raymond Anderson
                    Michael,
                    Just got the price through from West Yorkshire steel and yes, I was a bit shocked, but at least I can get the material that I need ,that's the main thing.
                    Raymond.
