Male hexagonal radiator key.
Home › Forums › General Questions › Male hexagonal radiator key.
  • #24074
    pgk pgk
      @pgkpgk17461
      #202533
      pgk pgk
        @pgkpgk17461
        All but 2 of my rads have typical square head bleed cocks.. those two I finally got to exmainign with a magnifying glass (old age is no fun) and the blessed things are male hexes.. 3/16 socket too small and 7/32th too big. 5mm too small and 5.5mm too big and I'm out of owned options.
        Anyone guess what they really are? 5.2mm or 13/64? Why in the name of the almighty would you choose a wicked size like that????
        #202535
          No idea what size they are supposed to be … but a Flank Drive socket would probably do the trick.
          mark costello 1
            @markcostello1
            Whitworth????!!!!!!wink
            #202542
            pgk pgk
              @pgkpgk17461
              I suspect it's a special size only known to the mystical order of diabolic plumbers and fishplate polishers.. Grr
              I suppose a few shreds of ally drink can stuck inside a socket might work or epoxy one on overnight???
              #202543
              jason udall
                @jasonudall57142
                Can’t answer the odd size thing but if you are pushed…cap head screw?…
                #202544
                jason udall
                  @jasonudall57142
                  And 6 mm dia would yield around 5.2 af
                  #202591
                  Gordon W
                    @gordonw
                    Chances are there is paint on the hex. Try a 5/16" socket and a small hammer.
                    #202597
                      Posted by Gordon W on 31/08/2015 09:08:55:
                      That would be a lot of paint !!
                      However [pgk] … you might check for a paint-filled screwdriver slot, if the valves are anything like these
                      #202629
                      Gordon W
                        @gordonw
                        All right! 3/16" then, or even 5mm.
                        #202638
                        Ian S C
                          @iansc
                          BA ?
                          Ian S C
