Magnetic Bench
Magnetic Bench
  • #228493
    Kenneth Deighton
      @kennethdeighton43272
      I have a problem . for some unknown reason the metal top on my bench work bench has suddenly become Magnetic, the top is approx 24" x 60" and there aren't any electrical connections on the bench or any batteries. can you help me to de – magnetise it ? . Ken.
      #32664
      Kenneth Deighton
        #228499
        Clive Hartland
          @clivehartland94829
          This does seem to be an odd thing that occurs now and then. I have heard that hammering the metal will stop magnetism?
          Some time back all the tools for my lathe suddenly became magnetic, picking up ferrous swarf which sometimes stuck in my hand but eventually it seemed to disappear.
          #228503
          pgk pgk
            @pgkpgk17461
            I read somewhere that one could magnetise metal rods by hammering them with ends N-S…? I think you can also get induced currents/magnetism from power lines and electrified railways?
            Perhaps turning the top around before hitting it or turning it at 90deg to any power line might help?
            #228510
            jason udall
              @jasonudall57142
              Two suggestions
              Its not always the tool thats .magnetic. .sometimes its the swarf
              And I tape paper to top of bench..then when clean top needed change paper taking all those pesky fines with it…then use tape to clean up if especially needed..
              #228566
              duncan webster 1
                @duncanwebster1
                WW2 ships were demagnetised using a large elctromagneti coil surrounding the ship, see
                It would be a lot of work, but if you want to go down that route you could start with the transformer out of a microwave, a length of welding cable and a variac to control the current. Noneed to move the bench through the coil, wrap it round, then ramp the current up and down. Having set this running hopefully someone with relevant experience will tell us where I've gone wrong.
                #228578
                Tim Stevens
                  @timstevens64731
                  You need to use an alternating current if this is to work, and reduce the current steadily down to nothing. Anything else is likely to magnetise the bench, and anything else within a few inches. And take your watch off before you start.
                  The process is called de-gaussing, and ships were done to avoid magnetic mines.
                  Cheers, Tim
                  #228581
                  Frances IoM
                    @francesiom58905
                    probably easier to replace with a sheet of stainless steel if just a sheet on top of a wooden bench (my solution to avoiding same having been annoyed by magnetised tools)
                    #228604
                    DMB
                      @dmb
                      My Father worked in Pompey dockyard during the last war, on the fitting of the copper cables around warship hulls.
                      #228611
                      Sandgrounder
                        @sandgrounder
                        Posted by duncan webster on 06/03/2016 10:58:17:
                        I would have thought a microwave transformer even when fed with a variac would have been a bit dangerous, if anything went wrong you could 2000V on the loose.
                        I've seen a homemade TV tube de-gaussing coil which was a few turns about the size of the tube and fed from the mains in series with an electric fire, the coil is then moved around in front of the tube and gradually moved away. No idea if that would work on a steel table though.
                        #228636
                          My understanding of Microwave Oven Transformers derives from an interest in building Tesla Coils. Tesla coils require a source of high-voltage high-current power, ideally more than 100mA at 6000V. The voltage can be obtained by connecting the high-voltage outputs of two or more MOTs in series. There is a high risk of insulation failure. For this and other reasons you have to be very careful using MOTs in a Tesla Coil. Perhaps the best advice is don't.
                          Individual transformers are also very dangerous. In normal operation in an oven their output will be at least 0.5A at 2000V. Although the shock alone could easily be fatal, being killed outright might be the least painful option. This is because the 3 or 4 kW available at the output will have no problem striking an arc into flesh and turning you into an electric fire. Burning will continue until someone switches you off.
                          An MOT could be used for degaussing only by rewinding the secondary with a few turns of very thick wire. 3000 amps at a volt or less would be good. It will still get very hot though!
                          Ships become magnetised when the steel they are being made of is struck repeatedly in alignment with the earth's magnetic field. The same mechanism probably magnetised Ken's worktop. Rotating the top through 180 degrees and beating it again might undo the effect. Alternatively after using a compass to establish which way round the top is magnetised, stroking it with a strong permanent magnet in the opposite sense might counteract the unwanted magnetism.
                          Heat also destroys magnetism but you would need to make the whole top very hot. Not sure that's practical!
                          Cheers,
                          Les Jones 1
                            @lesjones1
                            I think Duncan Webster's intention was that the high voltage secondary was removed and replaced with a few turns of very thick wire (Hence the reference to welding cable.) to make it into a low voltage very high current transformer.
                            Les.
                            #228647
                            Clive Hartland
                              @clivehartland94829
                              Maybe the best idea is to replace it with a sheet of Aluminium? Much safer to work on and it will not damage files etc.
                              #228661
                              duncan webster 1
                                @duncanwebster1
                                Posted by Les Jones 1 on 06/03/2016 18:28:31:
                                Les.
                                Exactly what I meant to say, as described in recent MEW for making a spot welder, but it would still be a lot of effort.
                                #228671
                                  Les.
                                  Sure thing Les. Good point.
                                  Apologies if what I said came over in any way as being critical of Duncan. Not my intention at all – I respect him.
                                  I was trying to pass on some info about a subject where I have some experience. No offence intended.
                                  duncan webster 1
                                    @duncanwebster1
                                    None taken I didn't express it very well
                                    #228709
                                    John Fielding
                                      @johnfielding34086
                                      Stainless steels are not all non-magnetic. Of the three common types two are fairly magnetic and one in almost non-magnetic.
                                      #228728
                                      Ian S C
                                        @iansc
                                        I once tried a micro wave transformer back to front, hooked the secondary to 230v, I think the out put was about 10v, open voltage/no load. One of these transformers with the secondary removed and replaced with heavy cable gives about 3v. I'v got 4 or 5 of these things waiting for me to think up some way of welding a seam in thin stainless steel.
                                        Ian S C
                                        #228759
                                        mechman48
                                          @mechman48
                                          Why not just replace it with plywood top, or as mentioned aluminium sheet, unless you use it for welding things on in which case any residual magnetism is/may be taken back to earth through the earthing cable… I think thinking… I'm not that far electrikery compos mentis.
                                          George.
                                          #228860
                                          Frances IoM
                                            @francesiom58905
                                            “Stainless steels are not all non-magnetic” – I suspect the most common sheet would be 304 (or A2 grade) as usually used in catering industry – 316(A4 and more corrosion resistant) is probably less commonly supplied by general metal dealers – I think 304 can be slightly magnetised by work hardening but certainly my SS sheet hasn’t as yet and allows easy removal of the small swarf that flies out from a small milling machine that used to stick in the plywood bench top
                                            re microwave-oven transformers I suspect many will be disappointed as newer models use highfrequency transformers fed by semiconductors as in modern switched mode power supply it will be only the now very old models that employ the large transformers
                                            #228944
                                            Ian S C
                                              @iansc
                                              Frances, Yes about modern power supplies, smaller lighter, and a whole lot more RF interference, as in the charger for my camera, and the power supply in my PC, and the 10W LED spot light that in the workshop. Copper is a semi precious metal, perhaps it's getting more valuable.
                                              Ian S C
                                              #228951
                                              Bob Rodgerson
                                                @bobrodgerson97362
                                                If Memory serves me well, back in the early 1970's when I worked in the shipyards on Tyneside all ships were degaussed. For sure the naval ships were.
