Machinability of Steels
Home Forums Beginners questions Machinability of Steels
  • #492918
    Chris TickTock
      @christicktock
      Hi Guys,
      I am trying to find a machinability index of steels that include EN24T and Silver Steel. I have so far failed miserably.
      Silver steel in its annealed state comes in at around 27 RC but cannot find what EN24T would come in at. I realise there are other factors that affect machinability but these points are a good starting point.
      Anyone help with these couple of points?
      Chris
      #10408
      Chris TickTock
        @christicktock
        #492921
        David Jupp
          @davidjupp51506
          T condition equates to 850-1000 MPa Ultimate Tensile Strength. Based on one of the conversion tables I use, that's 25 – 32 Rockwell C.
          Any of these strength/hardness conversions for steel are approximate, reality may vary from grade to grade.
          #492922
          Emgee
            @emgee
            Chris
            Some info here that may help you make the list. https://kvsteel.co.uk/steel/EN24T.html
            Emgee
            Edited By Emgee on 27/08/2020 10:43:24
            #492928
              Not found a simple list on the internet, but Tubal Cain's Model Engineer's Handbook, is useful for this and many other home workshop questions. Well worth £7.10 (cheaper second-hand)
              Machinability is a complex subject. A metal's hardness is just one of several factors and not one I'd draw conclusions from. Grain structure is a major influence and rarely mentioned in specifications, perhaps because heat treatment alters it. Instead specifications usually describe a metal's machinability from stock using words like 'poor' or 'average'. Silver Steel is 'good' while EN24T is 'excellent'. EN3A is 'average'.
              Bottom line, easy to get good results from 'excellent' metals like EN1A-Pb, expect bother with 'average' such as EN3A, and grief from anything described as 'poor'. In all cases, finish depends on correct tool, depth of cut and cutting speed.
              For most small workshop jobs requiring hardening, Silver Steel is safer than EN24T. Machinability is nearly as good as EN24T, but Silver Steel heat treats with less fuss. In most cases either would do, and I'd go with the one that makes the work easiest! Silver Steel.
              For comparing the properties of various steels to get a feel for what they're about, I find Machinery's Handbook convenient. The US steel classification system follows the effect of increasing Carbon more obviously than other standards, and Machinery's Tables also relate each steel to it's intended purpose. The European and other steel classifications follow different logic, no problem if you understand it, but not beginner friendly or easy to decode from scratch. The problem with selecting US Steels outside the US, is translating their numbers into a local equivalent. Nothing is ever easy…
              Chris TickTock
                @christicktock
                Posted by SillyOldDuffer on 27/08/2020 11:27:59:
                Thanks Dave,
                It would be easy for me to just blindly accept the use of Silver steel or EN24T both are up to speed. My issues are understanding why and that eventually makes for a better understanding and hopefully result. Totally agree with your analysis but it is good now to know I have EN24t as a viable alternative.
                I am guilty of not reading my books as often as I should but will make an effort. Will also see if I can get the book you recommend .
                Thanks to all posters really helpful especially converting tensile strength to Rockwell as an approximation.
                Chris
