M2.5 x 8 mm Insert Torx Screws
Home › Forums › Workshop Tools and Tooling › M2.5 x 8 mm Insert Torx Screws
  • #94901
    Kevin Bennett
      @kevinbennett25223
      Hi, a modification question
      I have broken a 2.5mm insert screw I had to drill it out in a DCMT 11T304 tip, as hole in the tip will take a 3mm standard screw has anyone modified tip holders to 3mm screw.
      as 3mm is easy to get and use a standard Allan key
      I can get one from RS components £1.25 each "outrages" cost for 1 off , or from china on eBay 10 off for £5.09 for + shipping.
      thanks Kevin
      #16846
      Kevin Bennett
        @kevinbennett25223
        #94902
          Kevin,
          Pricey little blighters aren't they!
          But …
          if ever there was a place you need top quality, and good fit, a toolholder must be it.
          Edited By Michael Gilligan on 21/07/2012 08:43:50
