Looking for tufnol strip
Home › Forums › General Questions › Looking for tufnol strip
  • #114637
    Philip Leith
      @philipleith92012
      Looking for tufnol supplier – 25mm by 4 or 5mm by 2000mm (for the hatch runners on a sailing boat). Any ideas where this might be got from?
      I can see sheets and rods online, but not much in the way of strip.
      #22527
      Philip Leith
        @philipleith92012
        #114638
        David Clark 13
          @davidclark13
          Hi There
          40 years in industry / engineering and I have never seen strip.
          We always cut it out of sheet or bar.
          regards david
          #114639
          Philip Leith
            @philipleith92012
            David
            That must mean there is someone out there who would cut me a couple of strips, perhaps? Who uses tufnol? If I knew that I could hunt it down.
            Philip
            #114642
            Andyf
              @andyf
              I was looking for a bit of Tufnol this morning. Here's a piece on Ebay which you could cut into strips. Only 2.5mm thick, though I suppose you could double it up.
              Andy
              #114643
              Philip Leith
                @philipleith92012
                Yes, saw that. It is a possibility but would prefer something more robust if I can get it.
                #114644
                  These people also do a cut to size service
                  Edited By JasonB on 17/03/2013 21:32:06
                  #114646
                  Philip Leith
                    @philipleith92012
                    Thanks – will contact them and see.
                    #114647
                    M0BND
                      @m0bnd
                      Sorry, I know this may be a bit late but …. http://www.tufnol.com/tufnol/default.asp
                      Andy.
                      #114651
                      Steambuff
                        @steambuff
                        M-Machine do Tufnol (Cut from Sheet) in 5mm thick.
                        They will usually cut to the size you require.
                        http://www.m-machine-metals.co.uk
                        John Stevenson 1
                          @johnstevenson1
                          I use a lot of tufnol strip as insulators and brush ring gear on electric motors.
                          The link Jason gave is the company I use and I have found them to be the most cost effective company and believe me when you are paying the bills you do look laugh
                          I keep every thickness in stock up to 12mm but unfortunately I only order in 600mm or 1M lengths max as i never have to do long peices and it's easier to store in 1M lengths than 2M
                          #114670
                          Philip Leith
                            @philipleith92012
                            I will measure up properly today. I think I can use two pieces end to end. Thanks for all the advice – very helpful indeed.
