Locking axis on Sieg SX2 mill
Home Forums Beginners questions Locking axis on Sieg SX2 mill
  • #217775
    David Brown 9
      @davidbrown9
      I cannot figure out how to lock the x and y axis on my Sieg SX2P mini mill from Arceurotrade.
      Does anyone have this machine who could let me know how to do this?
      I am sure it is obvious, but the design seems a little different to some other Sieg SX2 mini mills and so googling hasn't helped so far.
      David
      #7931
      David Brown 9
        @davidbrown9
        #217781
        Frances IoM
          @francesiom58905
          isn’t by using the long socket head in centre of the X + Y gib strips ? – the Y being a right pain to reach
          #217782
          John Rudd
            @johnrudd16576
            Posted by Frances IoM on 25/12/2015 22:36:12:
            isn't by using the long socket head in centre of the X + Y gib strips ? – the Y being a right pain to reach
            Well it is the method I use on mine with an appropriate Allen key….
            #217783
            Mike p
              @mikep
              Hi, David , I have this same mill and find the easiest way for me is to just tighten up the nut holding the adjustment handles providing you have no amount of backlash in the leadscrew this is all I ever need to do. Hope this helps.
              Regards Mike p
              #217848
              David Brown 9
                @davidbrown9
                Thanks a lot. I thought it would be obvious!
                It is the socket heads, I tried tightening them before, I just wasn't tightening them enough. Now both axis lock. The Y is indeed a pain to reach!
                David
                #217863
                John Rudd
                  @johnrudd16576
                  Posted by David Brown 9 on 26/12/2015 17:34:08:
                  It is the socket heads, Now both axis lock. The Y is indeed a pain to reach!
                  David
                  You So make your self an extended wrench, a length of bms 1/2 in dia.
                  Bore to take a hex key cut down, silver solder in, cross drill and add a tommy bar….QED….
                  Edited By John Rudd on 26/12/2015 19:26:33
                  #217888
                  Frances IoM
                    @francesiom58905
                    the same table is used in the ArcEuro SX1 – Graham Meek in EIM has commented on the somewhat poor gib design and suggests replacing with ones that more nearly fill the gap – I bought a 2nd SX1 to use as a base for some digital control (keeping my current working model available for making various addons) and decided to replace the gibs with somewhat wider brass being more easily obtainable, rather than Meek’s suggested cast iron, the originals being steel (which should work well on against a cast iron bed) – one of the original gibs was actually significantly banana shaped would happily spin round on a surface plate – I’d always had some problems with keeping the gibs on my original in good adjustment – easy movement in centre often resulted in too tight a movement at extreme travel whilst easing here tended to give some play in centre thus I suspect one of the gibs on my original is also banana shaped as Meek comments that only a small adjustment no more than hand tight of the centre screw should be needed to fully lock the gib
                    Edited By Frances IoM on 26/12/2015 21:44:46
