lead screw adise
lead screw adise
Home › Forums › General Questions › lead screw adise
  • #202426
    Malcolm Lines
      @malcolmlines40569
      I'm hoping that someone can help me with an issue that I am having with the Denham Junior Mk2 4.5" swing lathe that I have recently inherited.
      I have now got it set up and running but cannot engage the lead-screw nor the feed-shaft, The control levers on the saddle are operating fine, however I cannot get the two shafts to engage from the head-stock.
      Has anyone got any ideas or had a similar problem?
      Thanks for any advice
      #24071
      Malcolm Lines
        @malcolmlines40569
        #202461
        Bazyle
          @bazyle
          Are all the change wheels in place at the left of the headstock taking the drive from the spindle to the input of the threading gearbox? Note that in this lathe it starts at a small shaft projecting just below the back end of the spindle not the spindle itself. Is this turning? If not there is a problem inside the head.
          The lever on the bottom left of the gearbox selects movement left and right and probably provides neutral in the middle. The lever on the right selects between leadscrew and feed shaft. Are these levers feeling like they engage the gears properly? It is possible that the lathe was 'crashed' that is the saddle being driven right into the headstock under power and a gear broken. You should be able to rotate each of the leadscrew and feed shaft by hand and feel it loose when not engaged then resist when engaged as you fiddle with the levers.
          You have said you understand the saddle operation and it is working  so I assume you know about the operation of the lever on the right of the saddle.
          Edited By Bazyle on 29/08/2015 21:46:37
          #202463
          Bazyle
            @bazyle
            I assume you found this site. John is a forum member here so hopefully will see this thread in due course.
            Welcome to the forum anyway and it looks like you have a rather nice lathe there.
            #202695
            Malcolm Lines
              @malcolmlines40569
              Thanks very much for what has been the correct advise, the change wheels weren't engaged properly. They are now and both the leadscrew and the feedshaft are operating as they should. Thanks very much once again and now I can start to play.
              #202722
              Malcolm Lines
                @malcolmlines40569
                Can anyone please advise me as to how many change wheels I should so that I would have a complete set to go with my Denham Junior MK2 lathe, thanks in advance
