Julius 1″ Metric Minnie
Home Forums General Questions Julius 1″ Metric Minnie
Viewing 25 posts - 1 through 25 (of 26 total)
  • #515403
    Kevin Bennett
      @kevinbennett25223
      Hi All I am building Julius Metric Minnie traction engine and it calls for a 67mm od and a 63mm id copper tube with a 2mm wall thickness. Can i roll a tube and have a riveted seam or it a no no.
      Thanks Kevin
      #27851
      Kevin Bennett
        @kevinbennett25223
        #515408
        Nigel Bennett
          @nigelbennett69913
          Yes you can; it's a very common method. 2.5/8" x 14SWG might be obtainable…
          #515409
          Former Member
            @formermember12892
            #515410
              Best talk with your boiler inspector as he will have the last say and may want to derate the pressure due to the joint. I don't know if Julius' design has ever had any approval so best get the inspector to look over the whole thing before you buy any metal as there are a lot of deviations from Mason's original design and it will need updating to separate the manifold feeds. Plus the fact you could never assemble the engine as he's drawn it.
              #515412
              Former Member
                @formermember12892
                #515415
                Bazyle
                  @bazyle
                  An overlap joint gives problems with front tube plate and front firebox plate. Consider a strap joint. The rivets are only to hold it while soldering – the strength comes from the solder. Time was people used a castellated joint but I don't know if that is allowed now,
                  #515416
                  Nigel Graham 2
                    @nigelgraham2
                    There is no reason for a boiler inspector to reject thicker-walled tube or firebox plates for the same designed working-pressure, if that overcomes material-availability problems. (Using thinner than specified would obviously be a no-no, at least not without careful analysis proving no significant reduction in safety.)
                    Beware though – although thicker-walled tube would take higher internal pressure, it is not a reason for raising the working pressure for a particular boiler, without reviewing the entire design to assess that proposal.
                    Such changes might need dimensional revisions elsewhere on a traction-engine, as the boiler is also the engine-frame, transmission-casing and vehicle chassis – but note my point above about strength. The boiler on a loco and many steam-wagons is supported individually on a separate, strong chassis; but a TE boiler is the chassis, and subject to large bending-stresses.
                    Separating the feeds from the manifold and putting their bronze or gun-metal bushes in the normal places in the barrel, should please rather than upset a boiler inspector, too.
                    Whether as Jason says, the Julius design is not mechanically practical, is another matter, but his questioning its boiler design having ever been "approved" is interesting. Outside of the requirements placed on commercial boiler-makers, have any of even our best-known and long-standing, published designs been "approved"? I would say so, but by accumulated experience and proven repeatability.
                    #515417
                      BR are you sure that is 3mm wall and not 76mm x 3m long plumbing tube which only has 1.2mm wall thickness and may not be C106 as I can't see any 3mm wall on e-bay. Yes thicker tube would be OK if other items are adjusted to suit.
                      #515418
                      Former Member
                        @formermember12892
                        #515421
                          I've edited the post.
                          67 x 2.0mm wall is available as that is table "Y" thickness but not so readily available and you would likely have to buy a 3metre length, 1m if you are lucky. The usual plumbing thicknesses are known as Table "X"
                          #515423
                          Kevin Bennett
                            @kevinbennett25223
                            Hi thanks for the coms i have looked around for a 2mm wall I did find 67mm od on eBay i and 250mm long for £20.00 am awaiting a massage back on the gauge
                            Kevin
                            #515426
                            Former Member
                              @formermember12892
                              #515430
                                The imperial 2.5" tube which is the correct size for the imperial 1" minnie is available from most of the usual ME suppliers. Julius design for the metric one had a stock metric size picked off a chart somewhere with little thought to availability as table Y is not used that much.
                                Has anyone been able to find a working pressure specified anywhere on Julius' drawings?
                                #515433
                                Former Member
                                  @formermember12892
                                  #515435
                                    As I said in my first reply I don't know if any boilers made to the metric design have been made and presented to a boiler inspector, it is in effect a new design yet with not even a working pressure on the drawings it's hard to say what it's design is to be tested to. So anyone contemplating this design should seek the advice of their inspector before buying metal.
                                    I don't think many UK inspectors would take too kindly to the stainless steel spacers used for the firebox stays and the threaded firebox stay method is dated now, the bolts shown retaining the cylinder are an impossibility, etc
                                    Gear sizes are also seem interesting being a rounded up metric PCD and OD of DP sizes rather than converted to MOD1.25 and if you bend all the rear spokes the same as shown you will get a nasty looking wheel as can be seen in the GA drawings.
                                    Edited By JasonB on 25/12/2020 20:51:55
                                    #515441
                                    Kevin Bennett
                                      @kevinbennett25223
                                      Hi Jason you have looked at the drawings then, so you have helped me to abandon the metric version so i will get some tried and tested drawings from Reeves in the new year
                                      thank you i think this thread has ended
                                      A big thank you for all your help
                                      Kevin
                                      #515443
                                      Former Member
                                        @formermember12892
                                        #515461
                                          If you have the book it can be done from that without the drawings, how mine was made many moons ago. The book is basically a reprint of the ME series and the mags can be found in the depths of the forum files, just change the last number of the url to get the next mag.
                                          Worth looking at the three suppliers of castings as prices vary and some stock items that the others don't, as well as Reeves and Blackgates already mentioned GS Models do a fair number of items.
                                          #515464
                                          Former Member
                                            @formermember12892
                                            #515477
                                            roy entwistle
                                              @royentwistle24699
                                              Kevin I have sent you a PM
                                              Roy
                                              #515484
                                              Tony Wright 1
                                                @tonywright1
                                                Hello you can please your self .just as long as you are happy with the hydraulic test you will be fine.Its hardly likely you are going to be using it for public use is it ? There’s to many experts !who worry about everything. It’s just a metric version of the original and yes I do know what I’m talking about have built a Minne as well as 6 loco boilers (southern fed tested ) and at least 50 simple pot boilers . The only reason to get a certificate is if you want to sell it puts your profit up !
                                                #515542
                                                Former Member
                                                  @formermember12892
                                                  #515546
                                                  Kevin Bennett
                                                    @kevinbennett25223
                                                    Hi Br yes i am interested in the bits of the 1" minnie bits i will pm you
                                                    thanks Kevin
                                                    #515705
                                                    Roger Best
                                                      @rogerbest89007
                                                      Wheels more difficult than a boiler?
                                                      It must be a good boiler design.
