I ‘Want’ a bigger lathe. :)
Home › Forums › Workshop Tools and Tooling › I ‘Want’ a bigger lathe. :)
  • #288655
    Nick_G
      @nick_g
      I may 'want' one but the reality is I don't have the room or the money.! laugh
      Went to my mates today to get some keyways slotted into the hubs of some flywheels. I also asked him could I use one of his lathes that would take a piece of cast iron I have for the cylinder liner up its spindle bore so I could drill it out to something that I could later fit a bar through when it come time to line bore it.
      He pointed to a Colchester Triumph 2000 half hidden under a mountain of swarf and said that ain't being used at the moment so go ahead.
      Now this lathe has seen better days. But it was a dream to use. Solid, smooth and drilled a 38mm hole through this 200mm length of cast iron like a hot knife through butter. Not a single kick or flinch and did not make a single noise higher than when it was just turning over. – I suppose the quality of his drill bits, the edge he grinds on them and that cast iron is not the hardest of materials contributes. ………… But still I was impressed.!
      On departing I said to him that next time I had a free day I was going to come down with a gallon of paraffin and give the thing a damn good cleaning. He replied. "Will you heck wink as like. Clean them and they go rusty." laugh
      Anyway, I guess the saying that 'the heavier a machine is the better' carries some. …………. weight.
      Nick
      #18449
      Nick_G
        @nick_g
        #288656
          Did you not ask him if it had a 4-jaw big enough to take your hopperquestion
          #288658
          Nick_G
            @nick_g
            Posted by JasonB on 13/03/2017 16:57:33:
            Yeahh, he has. – Why what would your plan be.?
            Nick
            #288660
              Well assuming he has a big boring bar to match you could just bore it in the lathe
              #288673
              Nick_G
                @nick_g
                Posted by JasonB on 13/03/2017 17:18:12:
                He did tell me he had some very big boring bars with some kind of special damping on the heads. ???
                But I also liberated him of a couple of meters of steel to make a line boring bar out of. – Never done that so really would like to give it a go. (although I may regret it)
                Nick
                #288693
                Allan B
                  @allanb
                  I do like the big Colchester lathe's, dream to work on, and as you said heavy enough to not move no matter what you put in it
                  I have to admit to keep looking at them on ebay, as for space, I would make the space laugh
                  Allan
                  #288700
                  Chris Evans 6
                    @chrisevans6
                    I used a Triumph 2000 at work before I retired, I was not a full time turner as it was a jobbing shop most of my time was on a mill or spark erosion machine. The Triumph was a nice machine to use, worn when I started there and completely knackered 15 years later when I left. Typical of a lot of companies they would not spend any money on the machines to keep them in good order.
                    #288720
                    Tony Ray
                      @tonyray65007
                      The Triumph 2000 is a serious bit of kit; my dad used one as a toolmaker 7.5 horsepower if I remember correctly. He was a watchmaker so used to working to tight limits. he said it was his favourite machine in the workshop.
                      #289514
                      larry Phelan
                        @larryphelan54019
                        I also would like a bigger and better lathe,so, why dont I buy one? Simple,I dont think I,d know how to use it !
                        I have a small 6" Chinese job [ex Chester ] which does all I know how to do,no point in buying something better and maybe wreck it. 7.5 HP is a fair load for a home workshop,not sure your nabours would love you when you switch that on !
                        #289565
                        Nick_G
                          @nick_g
                          Posted by larry Phelan on 19/03/2017 17:11:03:
                          If they are in good order a big lathe is virtually silent. smiley
                          Nick
                          #289567
                          Nick Hulme
                            @nickhulme30114
                            Bigger lathes are for bigger work, if you upgrade to something too big you will lose top end speed and will find your capability for smaller work degraded,
                            – Nick
                            #289623
                            simondavies3
                              @simondavies3
                              Nick,
                              Maybe this one would be suitable for you – Dean, Smith and Grace, one careful owner (and a number of very careless ones). I am sure that the working surfaces are pristine under the coating of what looks like emulsion paint…..
                              (more photos in my album, sorry one is upside down but I can't see a way to invert it using the site software)
                              Spotted last year in a place that recycles building materials, so somewhat out of place in the sets of railing, shutters and second hand windows. Located on the outskirts of Aix en Provence – goodness knows what n°191 was doing here in the first place, but I suspect I can see its eventual destination.
                              Simon
                              Edited By Simon0362 on 20/03/2017 13:20:36
