How to make a Morse Taper
Home › Forums › Workshop Tools and Tooling › How to make a Morse Taper
  • #716424
    Vic
      @vic
      #716428
        The first five minutes reminded me of Rolf Harris when he was still acceptable:
        ” Can you tell what it is, yet ? “
        Nigel Graham 2
          @nigelgraham2
          Thank you for that, Vic.
          Very nice too!
          I wonder if that was made by the lathe manufacturers on one of their demonstration machines, but it was a very good lesson in how to turn such an awkward taper from the compound-slide. On a large lathe in tip-top condition of course – it would be a real struggle on an old, rather worn machines like mine.
          I do like that DTI holder, so simple to make but so effective. I wonder where you buy those saws? It did not look like a conventional slitting-saw but it was obviously right for the job.
          He used the standard ball tip to contact the template centre. I have seen advice to use an “elephant’s foot” (disc) probe in such situations. However, he was careful to show that he set to the probe to exact centre-height.
          A very clear and concise video too, because there were no distractions or clutter.
          #716432
            https://www.axel-gl.com/en/asone/g/TR61-2566-46/
            Edit:__ SwapLamp currently has 69 videos on YouTube … I think I could learn a lot
            https://www.youtube.com/@SwaplampJapan/videos
            Thanks, Vic
            #716478
            Vic
              @vic
              Yes, I subscribed to the channel a few days ago. Lots of good stuff. I just thought the Morse taper one could be handy for folks on here. It’s not something I would have attempted before but it is now if I need a special.
              #716501
              Chris Mate
                @chrismate31303
                I recently   cut an inside MT4 by also tracing it with the topslide set angle from a known MT4 for Boring Head tool.
                My two biggest problems were the boring bar reach/lenght/thickness without chatter/noise and the topslide travel range, luckily I added lockscrews to the topslide to make it more stable through the travel range after getting the lathe.
                -So I made a boring bar using drillrod & an incert received that did not chatter and made it to always used at full stickout, other than boring bars are usually used.
                -The travel of the topslide just made it to last 3/4 of travel.
                -The MT4 cut fit well afterwards, no problems.
