Oddly enough this was something i was doing back in the 1990’s !
I was working as a welder for a company that manufactured roller shutters and my job was to fabricate the roller drum .
After 6 months of hand tapping the cast iron cores that connect the drum to the axle then screwing in the 4 bolts and tightening i got jack of this especially as some drums had 4or 5 cores !
I brought my reversable air drill and impact gun in and proceeded to tap and tighten under power !
The 3/8 unc taper tap went in the drill chuck and i chose a drill to give 50% thread depth as this was mostly a shear loading effect on the bolt .
This was so succesfull that the boss purchased an air tapping gun and a new impact gun for the total sum of $1200 but this payed itself off in no time
I only ever snapped 1 tap in 4 years and it was my fault as i was rushing , no problem though as we just blew it out with an oxy – acetylene torch and re- drilled the core in a different position .
Some thoughts on the video :
1) At least he used a vice of some substance and no way was it going to flip over .
2)The gloves he was wearing are for chemical usage and will not protect him from much other than the WD-40 and besides that i was always tought not to use gloves with anything that revolves under power as you can’t feel anything and they may get pulled into the machine – this was mainly aimed at bench grinders etc though.
3) Impact guns /wrenches do not apply steady torque like a proper air tapping gun , they use impacts to turn things which could lead to stress fractures in the HSS tap .
It is a bit like hitting the end of a tap wrench with a hammer , each time that impact occurs the inertia will cause the shank of the tap to twist a little until the force required to overcome resistance of the cutting action is exceeded.
4) One would need to consider the time taken to set up the air compressor and assorted bits and pieces to tap holes and it would want to be a considerable amount of holes to gain a reward over poorly tapped holes that are not square to the material being tapped and the risk of breaking a valuable tap .
5) Proper machine taps would be preferred as thier spiral flutes are designed to pull the swarf up and out of the flutes and therefore negating any build up that could couse a jam .
6) A tap dropped onto a concrete floor is going to need carefull examination for damage to its cutting edges and could cause it to either need re-sharpening or pegging in the bin!
All in all it think this video is just another case ot a tosser with a camera !
Actually thinking of cameras, why have we not seen a DVD from MEW ?
I’m sure that a DVD with Harold Hall , Dave fenner , David Clarke and as many of the other contributors as they please doing a “HOW TO” DVD would be a go-er .
Ian
