How is it done ?,
How is it done ?,
Home Forums Beginners questions How is it done ?,
  • #5743
    Charlie,
      @charlie18171
      #77639
      Charlie,
        @charlie18171
        Hi Chaps,
        Must be somone here who knows how its done,I have a Myford
        super 7,And on the tumbler reverse two tuffnol gears,One of the gears has
        a single tooth missing,I have a new spare, Have removed the whole tumbler
        reverse unit but cant see how to remove the the damaged gear, It looks like
        it is a force fit in the unit,Dont want to get violent with it but is this a big hammer
        and a drift job???,
        #77640
        blowlamp
          @blowlamp
          I *think* there is a grub screw to lock the shaft into position.
          Martin.
          #77641
          Charlie,
            @charlie18171
            Hiya martin,
            Yes there is a long grubscrew with a locking nut that holds the whole
            tumbler reverse unit in the lathe,But my problem is how to remove
            the spindles on which the tuffnol gears run from the unit once i have it
            out of the lathe,But thanks for your input so far,
            #77642
            blowlamp
              @blowlamp
              Charlie.
              Yes, I understand that.
              Is there an Allen key type of grub screw through the side of the body that secures the spindle?
              Martin.
              #77643
              John Stevenson 1
                @johnstevenson1
                The spindle holding the Tufnol gear on is just a press fit.
                John S.
                #77644
                Charlie,
                  @charlie18171
                  Martin
                  No, once the unit is out of the lathe i can see no means of securing the
                  spindles to the unit,They seem to have been forced in or shrunk in, I can
                  see no way of removing them that dose not involve using a certiain amount
                  of force, And i am reluctant to use force, But there must be a way, I canot
                  be the first person to want to replace one of the tuffnol gears
                  #77645
                  Chris Trice
                    @christrice43267
                    I think you missed John’s post above.
                    #77651
                    Charlie,
                      @charlie18171
                      Yes Chris
                      you are right i did miss it, No excuse cept im old and its late, And
                      thank you John A press fit, That is basicaly what i wanted to know
                      Very gratefull for the input chaps thanks all,
                      #77655
                        @mike89748
                        Charlie: I had just this problem on a Myford I once owned. Got the spindle out OK, but pressed it back too tightly. Result was that next time I used the lathe on a high speed, the heat of friction set the oil on fire and burnt the new Tufnol gear, so it was back to square one… I was more careful second time around!
                        #77657
                        Joseph Ramon
                          @josephramon28170
                          You are Chuck the Muddle Engineer and I Claim My Five Pounds
                          Joey
                          #77663
                          KWIL
                            @kwil
                            Please also be aware that when securing the long grub screw, only take it to the point where it “holds” the unit in place, any further pressure not only makes the operation of the tumbler arm tight, it can also eventually force out the spindle which is a press fit as well.
                            #77735
                            Charlie,
                              @charlie18171
                              Thanks chaps
                              In spite of there being just one tooth missing on the gear wheel
                              everything is running well, Its just the damn ticking that gets me
                              down,Going to have to bite the bullet and do the job somtime soon
                              Charlie,
