home made lathes and milling machines
Home › Forums › Workshop Tools and Tooling › home made lathes and milling machines
  • #97678
    I.M. OUTAHERE
      @i-m-outahere
      Hi all , i just finished looking at a CD i picked up on E bay for a couple of bucks which has some weird , wonderfull but mostly bizarre plans from yester year and one was a small lathe made from angle ,a few blocks of steel and other bits 'n'pieces .
      The dovetails were not machined but rather some pieces of square steel were filed to the required shape then screwed to the saddle and likewise for the cross slide to form the dovetails .
      This has now got my curiosity running wild so i decided to do a search of the ME & MEW site looking for any articles about building a small lathe at home .
      Result = 0
      I am well aware of the stepper head project currently running in MEW but was looking for a small manual lathe instead 12" (300mm) or so long .
      Could make an interesting project down the track- maybe a Nano lathe or something .
      I can't remember seeing anything like this in the MEW back issues but it has been a while since i read them !
      Ian
      #16875
      I.M. OUTAHERE
        @i-m-outahere
        #97679
        Thor 🇳🇴
          @thor
          Hi Ian,
          There are several Yahoo groups about building your own machine tools. Here's a few:
          multimachine
          Multimachine-Concrete-Machine-Tools
          multimachine_india
          machinebuilders
          homemademills
          In addition there are several gingery_machines groups. May be you will find some of them interesting?
          Regards Thor
          #97680
            Ian,
            Try this thread for starters
            … L C Mason's book is a little gem.
              Some interesting ideas here too.
              … although it would be much easier to buy a watchmaker's lathe secondhand !
              I.M. OUTAHERE
                @i-m-outahere
                Hi all.
                Thanks for the replies and links .
                I ended up buying the LC MASON book as well as one by Gingery and err a few other as well – never let me loose in a book store !
                That reminds me i must hunt around on ebay to se if anyone is selling building Mastiff by Mason also – i know i can buy it through a store but it is expensive !.
                Regards …
                Ian
                #97689
                Cornish Jack
                  @cornishjack
                  Ian
                  I have a part-built Len Mason design lathe which would be a reasonably good basis for the complete machine. Made from gauge plate and bar with Phos Bronze headstock bearimgs. I have the cross slide more or less finished and a reasonable attempt at the lead screw. It has been sitting around for over 20 years and has gathered a 'patina' of surface rust!!wink. I think that I have some bits of gauge plate lying around somewhere as well. Machining was completed in the, then, local Tech school workshops. Didn't complete it due to change of domestic circumstances and purchase of a Unimat 3.
                  PM me if interested.
                  Rgds
                  Bill
                  #97692
                  Roderick Jenkins
                    @roderickjenkins93242
                    Ian,
                    I bought "Building Mastiff" from the Amazon market place about 6 months ago. Some vendors were asking £100+ but mine came from the States from a SH book dealer for less than £15 including postage, so I suggest you keep looking.
                    Rod
                    #97693
                    Ian S C
                      @iansc
                      There are some bits about home made machine tools in old(50+ years)Popular Mechanics. Ian S C
                      #97733
                      I.M. OUTAHERE
                        @i-m-outahere
                        Hi ALL .
                        Thanks Rod i will search for SH dealers and see what comes back , i think the only other place i managed to find it was through Hemminways but but the price tag left little to be desired !
                        Ian sc , i think that is where most of the material on the DVD is from as there is the odd mention of popular mechanics .
                        IAN
                        #97742
                        Ian S C
                          @iansc
                          You will see that a lot of the Pop Mechanics stuff is made from pipe fittings, and old car parts, ie con-rods from Model T Fords, and things like that, but at least the idea is there to work on.
                          Ian S C
                          #97748
                          Nobby
                            @nobby
                            Hi Guys
                            Heres my home made tailstock for my S7 Mk 1
                            leadscrew hand wheel
                            #97760
                              That's neat, Nobby
                              Sub Mandrel
                                @submandrel
                                Nice one Nobby,
                                Wouldn't look out of place on a field gun!
                                Nobby
                                  @nobby
                                  Hi Guys
                                  I get a buzz making bits for my old lathe . I got the basic bed and headstock . x slide for a fiver .
                                  Ive made and added the motor bracket & cover, X slide bracket and micrometer dials .and handles
                                  and gears studs etc. The gear cover i bought at a ME exibition to add to it .
                                  Nobby
                                  using fixed steady
                                  Edited By Nobby on 04/09/2012 22:44:31
                                  #99398
                                  Bazyle
                                    @bazyle
                                    Just for the record.
                                    I have found some of my copies of Mechanics from 1948 (LBSC Roedean) which I know preceded or followed the lathe design articles. I can't find the actual copies and fear I may have lent them to someone. I have definately seen an example of this lathe at a show in the last 15 years, possibly on a club stand.
                                    #99409
                                    Nobby
                                      @nobby
                                      Hi Guys
                                      I have loads of old M.E.s I will have a good look through them & see what I can come up with.
                                      I'm restoring a 1926 Exe lathe at the moment . I need to make a top slide for it to help when screwcutting. I found a source of round leather belting on Ebay
                                      Nobby
                                      Edited By Nobby on 25/09/2012 22:17:33
