Hercules Steam Crane Tubal Cain
Home › Forums › Help and Assistance! (Offered or Wanted) › Hercules Steam Crane Tubal Cain
Viewing 11 posts - 26 through 36 (of 36 total)
  • #457699
    BOB BLACKSHAW 1
      @bobblackshaw1
      Very slowly getting it finished, as I dropped it on the floor and smashed up the pipe work, arthritis in the hands didn't help.
      The two cylinder springs for oscillating, what springs are recommended as the springs I've got on will not allow the flywheel to slightly spin. Would a light spring allow a airtight seal, I don't want to keep stripping it down in case of me fumbling.
      Bob
      #457702
      Former Member
        @formermember19781
        #457705
        BOB BLACKSHAW 1
          @bobblackshaw1
          Thanks Bill, I have a lot of springs in the shed I will check for any 24g.
          #457717
          Former Member
            @formermember19781
            #459046
            BOB BLACKSHAW 1
              @bobblackshaw1
              I have made the crane and was surprised how much it can lift on air pressure, I think 10lb has been suggested, I was concerned that that weight will put a strain on the gears so halved that and it lifted that with ease. I want to make the boiler now but only have 67mm dia copper tube it calls for 2 1/2 inch dia, if I make the boiler to the same volume as the 2 1/2dia which would make the boiler longer would it operate the same, as it will have a smaller dia at the heat source.
              Bob
              #459116
              Bob Unitt 1
                @bobunitt1
                Bob, I wouldn't worry too much about the boiler, it has a pretty good safety-margin. I made mine, my first ever boiler. When I hydraulic tested it I misread my gauge, and took it up to 300psi instead of the 30 I was aiming for… Apart from a slightly distorted top it survived the experience, and has given good service ever since.
                Edited By Bob Unitt 1 on 23/03/2020 14:20:23
                #459125
                Former Member
                  @formermember19781
                  #459135
                  Former Member
                    @formermember19781
                    #459277
                    BOB BLACKSHAW 1
                      @bobblackshaw1
                      Thanks Bill
                      I keep making silly mistakes, it's an age thing I had 2 1/2 inch as 75mm mentally fixed and not 63.5mm
                      Bob
                      Edited By BOB BLACKSHAW on 24/03/2020 10:43:59
                      #459282
                      Former Member
                        @formermember19781
                        #464852
                        BOB BLACKSHAW 1
                          @bobblackshaw1
                          I've made the boiler and has come out quite well no leaks after silver soldering so I'm pleased with that out of the way. The crane on air test worked ok and lifted around 10lb s decided to have a go with the boiler and that to worked but noticed that 30lb on the gauge was registered and emptied the boiler rather quickly. All the mechanism is smooth and the cylinders have a viton o ring with a good fit, I checked for any obvious leaks but only slight from the moving parts which is expected. My question is, in the book the author said that the crane works on 10lb pressure which I find that mine cant, but with mine no obvious reasons that mine cant achieve the same, I found also with air pressure no way would 10lb work.
                          Bob
