Help with Ward 3A
Help with Ward 3A
Home Forums Manual machine tools Help with Ward 3A
  • #427828
    David Canham
      @davidcanham77137
      Hi People,
      Can anyone help with the oil / grease points on a Ward 3A Capstan.
      I am helping to clean and re adjust the lathe and it has a lot of possibly grease nipples on it. But, if it's any thing like my Super 7 then most of what look like grease points are in fact for oil.
      I have tried the internet but there isn't much out there. Any help would be appreciated.
      David.
      #13632
      David Canham
        @davidcanham77137
        #428578
        Chris Buxton
          @chrisbuxton55939
          Hi David,
          I know nothing about Capstan Lathes. But I do wish you luck in finding those answers …
          Kind regards,
          Chris
          #428584
          Ian Johnson 1
            @ianjohnson1
            This post reminded me we used to have two Ward capstans in our workshop, mainly used for making studs and bolts. And I can't remember greasing them. I used to squirt the ways, rotating and sliding surfaces with machine oil.
            I would think grease is too sticky for a capstan, doesn't flow where you want it to, and would slow down the operation, speed is essential when working a capstan. Oil will also flow better and not turn into grinding paste.
            Hope this helps
            Ian
            #428744
            David Canham
              @davidcanham77137
              Thanks Chris,
              Ian, i think i will stick to an oil as suggested. The people that own the lathe do have a 5Lt drum of 32 grade hydraulic oil.
              If i oil a grease point there is probably less of an issue than if i grease an oil point, lets hope so anyway.
              David.
              #428749
              Brian Wood
                @brianwood45127
                David,
                Give them all a good oiling too, the passages could well be choked with grease that is in the process of drying out and it may take some shifting.
                If you can look to see evidence of penetration.
                Regards Brian
                #428751
                David Canham
                  @davidcanham77137
                  Thanks Brian, will do.
                  David.
                  #428766
                  Nigel McBurney 1
                    @nigelmcburney1
                    I worked on a Ward 2A for six months during my apprenticeship,we only had an oil gun, the oil was Shell vitrea (no doubt long disappeared) i think the viscosity was 34 anyway it was about the same as Castrol xl (30 sae),same oil was shot over the slideways. Nice machine, if you were not working it on a winter monday morning with very cold soluble oil flying everywhere,In the six years I was with the company it was used most days mainly on no ferrous materials and never went wrong or needed adjustment.It was regularly cleaned as the non ferrous swarf was valuble and when there was a change of material ,thorough cleaning was essential to avoid contamination of the swarf.In those days none of our machines hydraulic oil.
                    #428795
                    Ian Johnson 1
                      @ianjohnson1
                      Posted by David Canham on 12/09/2019 17:33:14:
                      Sounds like a plan. Any oil is better than no oil.
                      Ian
