Help needed from a kind engineer for project
Home › Forums › General Questions › Help needed from a kind engineer for project
  • #177990
    James Fraser
      @jamesfraser88735
      Hi all,
      I really need someone out there kind enough to help me lathe some aluminium into a simple cup. One cup with m36x2 outside thread and one cup with a m36x2 outside thread. I am stuck and no local engineers will help me unless I place a ridiculously expensive order. Please PM or reply if you can assist me. I know it’s cheeky to ask but I always remember my dad helping individuals when he could with machining.
      Thank you
      James
      #23694
      James Fraser
        @jamesfraser88735
        I require someone to help me get project off of ground
        #178947
        Thomas Gude
          @thomasgude37285
          Hi James,
          I'm probably not your man as I have only just started to get my teeth into screw cutting (no pun intended). You ask for two of the same – was one of those meant as internal thread?
          Anyway, it will probably help your cause if you tell us where you're based as it's always easier for someone to help out if they're local.
          #178975
          Clive Hartland
            @clivehartland94829
            Perhaps once again a drawing will give a better idea and draw in a person who would be happy to make your parts.
            #179038
            Brian Wood
              @brianwood45127
              Hello James,
              PM sent
