GENERATORS IF THE LIGHTS GO OUT !
Home › Forums › The Tea Room › GENERATORS IF THE LIGHTS GO OUT !
  • #610763
    noel shelley
      @noelshelley55608
      With the prospect that the lights may go out A friend recently bought a generator that was rated at 6Kw and powered by an engine rated at 6.5Hp !
      1Hp = 0.75Kw, 1 Kw = 1.33Hp. These figures assume No losses,of any sort. The alternator is quite small, is this a clue ?
      I can not make these number add up can anyone else ?
      My own old Homelite generator of 2.5Kw has an 8Hp engine, and a new small 1Kw uses a 2.6Hp, Both these value make sense !
      For those thinking about buying a generator I would suggest that a few simple sums are done to verify that it will produce something like the power claimed ! Noel.
      #36955
      noel shelley
        @noelshelley55608
        #610767
        AJAX
          @ajax
          Perhaps the alternator was rated at a theoretical maximum of 6 kW. In typical marketing BS they failed to point out the engine was incapable of driving the alternator to its full potential.
          #610779
          not done it yet
            @notdoneityet
            And don’t forget that kVA is often quoted rather than KW. That makes about 20% difference. The general rule for small generators is 2HP per kW.
            #610782
              Posted by AJAX on 22/08/2022 18:55:22:
              Could be a mistake or ratings confusion.
              Motor ratings aren't fixed limits. If the seller is playing the game 6.5HP means the engine is capable of outputting nearly 5kW continuously, which a 6kW alternator will handle comfortably, supporting a load of about 4.4kW without bother.
              But say the load includes a deep-freeze which comes on intermittently every hour or so and demands an extra 1.5kW for 5 minutes. Will the extra demand stall the engine because it has to deliver more than 6.5HP?
              Probably not: most engines can exceed their ratings for some time. This happens in a car, when the driver drops a gear and floors the accelerator whilst overtaking. The engine sees an easy load allowing the pistons to move faster and consume more fuel. It's power output at high RPM will be considerably above the manufacturers rating, which describes the engines ability to deliver power continuously under ordinary driving conditions.
              I think the generator engine would do the same, providing an extra couple of HP for some time. The awkward question is how long? The answer depends on conservative the seller is. He might assume users will only use the generator infrequently, and his inexpensive machine will last beyond the guarantee even if abused. Or he might be selling a top-end generator, expected to do solid hard work for several years. An owner buying a generator to cover occasional power-cuts probably doesn't need to spend big money on the long-lasting generator.
              A mistake is more worrying – the generator might not be what it seems at all! And those numbers are strange…
              Edited By SillyOldDuffer on 22/08/2022 19:42:06
              #610846
              not done it yet
                @notdoneityet
                I would disagree with that statement. Just watch cars on dynos when being tested. They measure maximum power and quote the engine revs for that power. Some engines will provide more power than the standard results – but that is only because the manufacturer makes sure their engines will meet the minimum specified. It is not usually more than 10%.
                The specifications quoted by the seller of the product referred to in this post are simply wrong – and misleading to those that don’t understand these things.
                #610858
                noel shelley
                  @noelshelley55608
                  "the specifications quoted by the seller of the product referred to in this post are simply wrong – and misleading to those that don’t understand these things. "
                  Thank you NDIY, that was my take on the specs ! The size of the alternator would have put me in the mind of 2Kw, it also had a 3 PHASE output ! I also have an Onan 4Kw with a twin cylinder that will be rated at at least 10Hp. It very much depends on the inrush current and load as to what a generator will drive. I came across a 2Kw on a briggs and S 6.5Hp that would stop DEAD if a small 250W compressor was plugged in, yet happily drive a 2Kw kettle or 0.75Kw drill !.
                  If thinking of buying a generator I would suggest that you convert the Kw output to Hp (1Kw=1.33Hp) and multyply by 2.5, if this =s the engine power (or there abouts ) it will work ! Noel.
                  #610859
                  pgk pgk
                    @pgkpgk17461
                    Other things to consider.
                    A while back we had a powercut = No borehole pump. We had a builder on site and I borrowed his ancient little 2KW Honda frame genny which ran that pump nicely. As a result i bought a fancy new 'suitcase' inverter genny rated at 2.5KW. Officially portable I’d call it luggable.. OH couldn't cope nor pull start the thing. Worst of all it didn't run the borehole pump – I think because it was modern and fancy and didn't like the start-up current effects. In the end I sold it and bought a 7,5KW old tech for the same money – electric start and on wheels – which happily runs borehole, fridges and freezers, internet and PC;s etc and one can even swap the loads for the few minutes needed to boil a kettle or run a microwave. Conveniently it even has 2 x 16A type blue sockets, 2 x 120v yellow sockets and a 12v output option and a huge petrol tank.
                    #610866
                    Howard Lewis
                      @howardlewis46836
                      Electrical power tends to be the same irrespective of ambient pressure or temperature.
                      Power for I C Engines is usually quoted under standard conditions (Often 20'C and 750 mm Hg. There are BS, ASA and ISO standards ), so on a cold winter day, possibly with high barometric pressure, the engine might be capable of delivering more than its claimed "6 hp"
                      On a hot day with low atmospheric pressure it won't!
                      Which is why many super or turbocharged engines use intercoolers to increase the density of the air going into the cylinders.
                      And this ignores any variation in the calorific value of the fuel and it's temperature, or local humidity!
                      (We always rated our engines at 40'C fuel inlet to the injection pump. A competitor, in one field, used 20'C for their power claims. On one engine this amounted to a 18 bhp difference!
                      Many years previously, one engine used an injection pump, known for churning the fuel and heating it. As the engine ran, you could watch the load carried by the dynamometer decreasing as the fuel temperature increased. Consequently, we only measured power output at a set temperature. )
                      #610873
                      PatJ
                        @patj87806
                        I have noticed that portable generator manufacturers inflate their kW ratings by using "peak" instead of a more practical "continuous".
                        Peak may help a bit if you are starting a motor, but if you exceed continuous, you open the breaker on the genset.
                        I do like the new quiet generators, since you can barely hear them running, even standing close to them.
                        Very nice on the ears.
                        #610875
                          How to get more power out of an IC engine deserves it's own thread! There's a lot to say on the subject.
                          But I stand by my assertion that the single figure HP rating of an engine should be it's average continuous output, not the maximum it's capable of.
                          Back to basics, one horsepower is the average amount of steady protracted work that can be delivered by an average horse. I recall it was first defined formally by James Watt measuring the amount of water lifted a known height by a team of horses working a bucket pump powered by a horse gin in a brewery. (The horses walked continuously in a circle to drive a windlass.)
                          An average horse can deliver about 750W steadily between meal breaks. A fit man delivers about 200W in the same conditions. Both horse and man can do more work in short bursts, easily exceeding the average. A trained athlete can output about 1.5kW, but not for long. IC engines also have power curves, but the quoted rating should be the power the engine can deliver continuously without overheating or causing excessive wear and tear. 'Should be' because we all know about salesmen!
                          Vehicle dynamometers don't tell the whole story – for example, they chart an engine's power curve for a particular load, and that load is unlikely to show what the engine would output flat-out in second-gear hauling a heavy caravan up a steep hill. (By a driver who ignored the steam, temperature gauge, noise, and smell!)
                          Modern cars are 'quite interesting' because they're fitted with engine management units that override what the driver does. My eco town car's engine is tuned for good fuel economy and nothing I do at the controls makes it sporty. There is a sporty model of the same car with much the same engine, except the EMU is set for performance rather than economy. Unless you know how to reprogram an EMU it's easier to overdrive mechanically managed engines because they're less governed.
                          Fundamentally the maximum power output of an IC engine is limited by the amount of energy that can be extracted from the cylinders in a given time. That suggests several ways of improving power output:
                          • Run at higher RPM
                          • Optimise ignition timing for power output (rather than torque, economy or emissions)
                          • Increase the volume of the cylinders, diameter and depth
                          • Increase compression
                          • Improve fluid flow through valves, exhaust and intake
                          • Improve fuel/air mixing with better carburation or injection (not easy)
                          • Optimise fuel/air proportions to match current operating conditions. (lean and rich mixtures)
                          • Increase fuel density in the cylinder by blowing the intake with a supercharger or turbocharger
                          • Increase fuel density by cooling the intake with an intercooler after the blower
                          • Increase fuel density by injecting methanol or water into the mix
                          • Increase energy density by replacing air with Oxygen
                          • Increase heat value of the fuel (exotic, because oil is almost as good as it gets.)
                          Nitrous Oxide works well because it combines 3 effects. Inside the cylinder, N2O adds a useful amount of extra heat during the burn, but it's main benefit is to chill the fuel/air mix going in so a greater weight of it ends up in the cylinder. Another important benefit is that the small amount that can be carried means it can only be applied to the engine in short bursts. As the boost doesn't last long enough to seriously overstress the engine and it's cooling system, Nitrous Oxide can be fitted without needing other parts of the engine to be uprated
                          The downside of these techniques is the engine takes a thrashing that reduces it's useful life. Formula 1 engines only last one race. Balancing performance against reliability is tricky.
                          Anyone on the forum deep into souping-up cars? I'm interested in the theory, but have no practical experience.
                          Edited By SillyOldDuffer on 23/08/2022 11:00:57
                          #610881
                          not done it yet
                            @notdoneityet
                            My first generator, 45 years ago (after getting married and moving away from the farm), was a 1.5kW alternator with a B&S engine. It would not start my freezer (about 160W) unless I over-revved the engine. Once started, the freezer was no problem and other loads could be added to the genny.
                            My current generator (~4.5KVA Stamford genny, with an E75 Hatz diesel engine) has hardly been required in the intervening years.
                            It was used, by a friend, for extensive building projects over a period of several months, but not often required by me. The alternator has a large (as in ‘very heavy&rsquo rolled-steel magnet frame and, as such, has far superior motor-starting ability than most small sets (those that are stator wound with electronic AVRs) . It will fairly easily drive a 3kW heater, but smokes heavily with a 3.5kW load. I suppose 2.5kW would be its usual ‘sweet-spot’ power (about 80% of maximum load).
                            I am currently in the process of making sure it is serviceable for this winter! It will be noisy if the whole area is blacked out, so I would be happy to feed close neighbours with a light extension lead (2A fuse?).
                            At the present time, I have some old-stock red diesel I could use up for a few hours of operation. That fuel likely cost a few pence per litre, so at the moment I could be generating leccy for less than 5p/kWh – but not for long!
                            #610882
                            noel shelley
                              @noelshelley55608
                              A WORD OF CAUTION ! Not all generators have Automatic Voltage Control, especially cheap ones ! Modern electronics will often fail due to a spike – caused by the turning off of some other device connected at the same time ! The experts will have many and better ideas but one trick is to leave a 100W incandesant bulb (or other load, NOT LEDS) running, to take the edge off the spike! So many modern items have electronics in them that take a dim view of over voltage – even for milli seconds, for computers Etc a proper spike protected socket may be a good idea. Noel.
                              PS. Since Stamford alternators has been mentioned, Back in the 70s ( winter of disontent and powercuts) Stamford produced Transformer controlled alternators, the field current was inducesd in a transformer from the output,. How stable WAS the voltage ? NDIY, in servicing the stamford check the brushes are long enough and free in the brush boxes.  N
                              Edited By noel shelley on 23/08/2022 11:27:39
                              Edited By noel shelley on 23/08/2022 11:33:13
                              #610884
                              not done it yet
                                @notdoneityet
                                Dave,
                                You are greatly behind the times (Colin Chapman/Lotus years?) when F1 engines were first built to just last one race. Current F1 teams are restricted to, I think, three engines for the whole season. Any extra power units required attract grid position penalties.
                                Many years ago we used to ‘soup-up’ Ford car engines. It did not matter how much more it could be revved the engine would not make extra power – limited by mechanical (eg valve bounce) or air flow (head/valve and manifold limitations. Back then, we had no means of avoiding ‘pinking’ electronically – as they do these days – so compression ratios and timing were just set for the fuel used (octane rating).
                                #610885
                                Ady1
                                  @ady1
                                  If you're going to buy something along these lines check it out on youtube first
                                  There's an army of guys making youtube vids about them
                                  taking them to bits, wiring up load meters/oscilliscopes etc
                                  #610892
                                  peak4
                                    @peak4
                                    Posted by not done it yet on 23/08/2022 08:44:56:
                                    It is possible to increase the fuelling and measure it on a dyno, as this demonstration shows, but I think they may have gone a wee bit beyond 10%
                                    Lots of videos of this test, but I chose this one as you get a bit more detail if you freeze frame after 30 seconds(ish)
                                    N.B Warning, if you have the sound turned up, there is a bit of swearing towards the end.
                                    There's a bit more detail on this link
                                    https://www.motor1.com/news/509880/dodge-ram-massive-engine-explosion/
                                    Bill
                                    #610911
                                    Howard Lewis
                                      @howardlewis46836
                                      The standard rating an engine is at Full Load Rated Speed.
                                      If it says "6 hp" that what bit should deliver over a long period, (Thousands of hours not hundreds ) unless it mis a tiny engine ( <250 cc ? ) being pushed right to the limit
                                      For people like Enzo Ferrari and Colin Chapman, it was enough for an engine to survive just long enough to win the race.
                                      For mere mortals like us, the engine that we use, output is traded for life. A petrol engine producing 259 bho per litre is possible, but it won't last as long as an otherwise identical one producing 50 bhp per litre.
                                      We hope that our car engines will run reliably for 100,000 miles or more. So we are looking for a rating that is more or less continuous, even if we use maximum power for a very small percentage of the time..
                                      No point in having a machine that spends more time being repaired or tuned than being used.
                                      Nigel Mansell said that that was why he sold his Ferrari.
                                      Also a short life racing engine will not be as tractable as one with less extreme valve timings.
                                      The Sabre Marathon engine for power boat racing was a diesel giving 100 bhp per litre. Tractable? No way!, Would not even start unless the jacker water was 70'C or above. Open the throttle too quickly and the boat would come off the plane and sink into the water under a dense black cloud! But when it was on song!!!!!!!!!!!
                                      The early BMW engines tuned for use in Frazer Nash cars were, for their time, powerful, but torque tended to increase quite suddenly as the engine speed increased. This made the car's handling quite difficult..
                                      It also meant that faced with a hill, it was no good expecting the engine to slog at low speeds.
                                      Scavenge blown two strokes tend be the same. It was not for nothing that Foden FD6 powered lorries had 12 gear ratios available. Little low speed torque, so had to kept spinning fast…
                                      Torque back up is unimportant in a genset; it is a constant speed engine. An alternator gen set should be governed so that the speed varies by 5% or less between full and no load, (Absolutely necessary if expected to run in parallel with one or more other gensets, or an infinite bus, aka the mains )
                                      Who wants anything frequency sensitive, such a mains fed electric clock or induction motor, running at varying speeds?
                                      If "mains" frequency is wrong, fluorescent tubes might be more difficult to "strike" since they rely on resonance to produce the spike for starting.
                                      For multiple sets, one was usually chosen as the Master and fitted with an isochronous governor, where the speed did change with variations of load, and the slave, droop governed, sets were paralleled with it.
                                      Without such a Master set, trying to keep two or more alternator sets in sync is almost impossible.
                                      We had a genset back, that had powered fluorescent lights during construction of the channel tunnel. It had covered over 27,000 hours, and was good for more. Ideal conditions, constant speed and load with strictly observed maintenance schedules. TML demanded it back after it had been stripped and inspected!
                                      Diesel electric locomotives tend to run the engine at more or less constant speed controlling output by varying the field on the alternator.
                                      A DC genset needs to run at more or less constant speed, or output voltage varies.
                                      But don't expect too precise, let alone isochronous, governing, or an extremely long life on a "Built to a low price" genset.
                                      You get what you pay for!
                                      #610934
                                      Ady1
                                        @ady1
                                        On a small trawler type ship I audited the genny was a ford 1600 diesel which had done an outrageous number of hours without a problem
                                        TX1 nissan diesel taxis weren't run in until you had 500,000 miles on the clock
                                        #610938
                                        Pete Rimmer
                                          @peterimmer30576
                                          Posted by SillyOldDuffer on 23/08/2022 10:57:10:
                                          Nitrous oxide increases the amount of oxygen in the intake charge, allowing more fuel to be burned. Simple as that. Gains from increasing the density of the intake charge by cooling are minimal.
                                          #610939
                                          Pete Rimmer
                                            @peterimmer30576
                                            Double post
                                            Edited By Pete Rimmer on 23/08/2022 18:36:56
